Brian Coat
Brian Coat
99
Re: Renault V6 Power Unit
On the Ferrari and Merc engine threads of this forum
Cold Fussion wrote:
FPV GTHO wrote: It's possible, but they could also be desperate for any reduction if thr drag increase is as big as predicted.
The heat rejection figures should be naturally going down anyway because of the ever increasing engine efficiency.
That would be relevant to the coolant radiators, but Renault has issues that require massive intercoolers.
Anything is possible but it's my opinion that the teams would have exploited all the low hanging fruits in the cooling system drag reduction. Are the Renault intercoolers air-air or air-water?
PlatinumZealot wrote:Engines will work harder to move heavier draggier cars hence the 5% alotted fuel increase. More heat will be rejected on average but only just so. The cars will be faster through the corners so higher exit speeds means less acceleration out of the corners which help fuel consumption.
The cars will punch a bigger hole trhough the air so there will be lower pressure around the back sides. Heat will be more easily extracted from the sidepods.
The 5% fuel increase is only for the race fuel total and not the fuel flow limit so shouldn't affect any heat rejection.
Yes it would. The race will be completed in a faster time with more fuel burnt. In the bigger picture you will be rejecting more heat in a shorter time. As i said more heat but only just so.
Cold Fussion
Cold Fussion
93
The race-averaged heat rejection power will go up but the WOT heat rejection power will remain the same.
We are talking avout cooling right.
The same engine with the same horsepower will have different cooling requirements under different conditions. Not that hard to see.
NL_Fer
NL_Fer
82
I'm with Platinum Yoga here, cooling is aerodynamics. Lower pressure behind the car will increase the airflow through the engine and radiators.
About the intercoolers, i remember the Ferrari uses 1 Air2Air radiator mounted on the upper back, getting air from the intake hole on top. And 1 Air2Water in the front, behind the driver with a radiator in the sidepod.
lio007
323
http://www.motorsport.com/f1/news/renau ... 61660/?s=1
This might get interesting how that pans out.
I'd really like to know what kind of new concepts they are going to introduce! Is anybody close to Viry around here, to give us some hints :D (e.g. is the dyno testing promising, how's the relationship with Ilmor,...)
I was also wondering if Renault is using RBR's VTT. I think it would be an advantage to test cooling requirements,... of the new PU in a real chassis.
Muulka
Muulka
lio007 wrote:http://www.motorsport.com/f1/news/renau ... 61660/?s=1
The big admission in that article is that the gap to Mercedes is significantly more than 3%. I think that that would tend to corroborate Max's statement that the deficit is 50hp. The difference is clearly very big
Godius
186
djos wrote:
PlatinumZealot wrote:He said the Ferrari menu was easier to navigate. Not sure if he went as fas as knowing the characteristics of his 2015 Ferrari engine versus Raikkonens 2016.. I think you Maxie fans are stretching things too far.
I'm not a Mad Max fan but I think some of you are underestimating the current crop of drivers, they can usually detect subtle wing changes so why wouldn't they be able to detect subtle power unit differences?
You think a lot but don't have any facts to back things up.
hurril
hurril
Is your post any better?
roon
roon
412
VTT?
FPV GTHO
FPV GTHO
Virtual Test Track.
Muulka
Muulka
please just ignore me
Nickel
Nickel
Muulka wrote:It's hilarious how people have just accepted the random reports of Red Bull having this 'VTT'. Totally unsubstantiated and I don't know why it's the subject of so much obsession.
Actually, it's been reported in a few places. AMUS reported on it as early as May.
here is a translated snippet: The driver sits in the simulator, and in an adjoining room, the car rides on wheels, including the engine, transmission and tires, as if it were on the racetrack. External influences such as temperatures can also be simulated. The lab was never so close to the race track. This is how Renault also benefits. "In Viry, they are not yet ready with the test rigs," reports team consultant Helmut Marko.
Original article (German) : http://www.auto-motor-und-sport.de/form ... 03249.html
I'm curious. Wouldn't be easier to download the simulator log file and use it at a time and place convenient to the other party?
Nickel
Nickel
PlatinumZealot wrote:I'm curious. Wouldn't be easier to download the simulator log file and use it at a time and place convenient to the other party?
easier? maybe. however doing so might simply put off the work until later. I take it the idea of the VTT is to simulate as many variables at once as they can, hence having the driver in the loop. the rolling road/dyno setup is thus simulating driver errors, habits and preferences instead of a computer programmed to simulate a lap.
Other than not having to build the infrastructure to tie the two together, what do you imagine is the advantage of using the simulator log to run the test bed at a later time?
