Red Bull RB20
Owen.C93
Owen.C93
191
Re: Red Bull RB20
Shocked that the endplates weren't already at the maximum width in the regs. Guess they've just been running a beamwing that hasn't been at full width all season.
Re: Red Bull RB20
SiLo wrote:
21 Jun 2024, 11:34
21 Jun 2024, 11:14
Yet more inlet tweaks. They say the sidepod/floor changes are cooling related but hard to believe
Interested to see what's going on with the beamwing/endplate
https://i.imgur.com/ZL8KsYU.jpeg
The Europe races are traditionally quite warm, so it does make sense.
Really they've modified the inlet geometry to exploit high pressure air better meaning less cooling outlets required. They're not saying that they've increased the inlet area or anything. We'll see from the photos
Re: Red Bull RB20
I think the lower part of the sidepod may be slimmed down with a larger & taller g-line undercut, based on the limited pictures from Thursday
Sergej
Re: Red Bull RB20
let's wait for some pictures, sidepod inlet change doesn't sound like a simple circuit specific update, seems more in line with their development path in that area
Re: Red Bull RB20
taller g-line undercut as expected, and they have optimized the vertical inlet placement (reduced area of inlet). The underside of the shark inlet is now scalloped . Looks like some forward floor changes as well.. but not 100%. top deck behind SIS tube looks like pushed lower
comparisons by Nicolas Carpentiers [@NicolasF1i]
on Twitter
Scalloped bottom of the sharkmouth inlet & possible top deck change highlighted regions
Aero gandalf points out that the leading edge has been treated carefully on vertical inlet to reduce separation
Sergej
Re: Red Bull RB20
this is definetely a performance upgrade rather than circuit specific/cooling/other bulls*it; probably reported as circuit specific because they used the loophole about cfd hours on cooling development to produce it.
Henk_v
Henk_v
89
Re: Red Bull RB20
There is no such loophole for external parts. Only internal ducting.
Venturiation
Venturiation
103
Re: Red Bull RB20
Henk_v wrote:
21 Jun 2024, 13:07
For the #SpanishGP, #RedBull revised the sidepod inlet, more for aero goals than for cooling as stated (teams can run their car in the windtunnel as much as they want as long as it's for internal airflow). Narrower sidepods > more space for airflow to Coke bottle area
There is
https://x.com/NicolasF1i/status/1804098702815940812
Re: Red Bull RB20
Venturiation wrote:
21 Jun 2024, 13:25
Henk_v wrote:
21 Jun 2024, 13:07
There is
internal airflow yes. They can't take measurements other than pressures in the internals.. but clearly using this unlimited tunnel time is part of their strategy with the rb20 given the sheer number of inlet/cooling optimizations they've made
SiLo
144
Re: Red Bull RB20
Venturiation wrote:
21 Jun 2024, 13:25
Henk_v wrote:
21 Jun 2024, 13:07
There is
I'm certain this is for internal flow only, they aren't allowed to use it to see external flows. I'm not even sure they can run the car in the wind tunnel. It might just be CFD runs.
Felipe Baby!
Re: Red Bull RB20
RB20 rear end with new beamwing/endplate arrangement
high downforce beamwing for Barcelona.
Autosport photos by Giorgio Piola
Side view of new sidepod/undercut geometry
front view
Sergej
Re: Red Bull RB20
Re: Red Bull RB20
I noticed this during qualifying.
Red Bull moved their flap adjuster inboard.
Curious move in the middle of all this discussion over flexing wings.
Re: Red Bull RB20
Extra louvres maybe, but apart from that I can't see anything at a glance
TimW
TimW
36
Re: Red Bull RB20
Sevach wrote:
22 Jun 2024, 19:14
https://cdn-1.motorsport.com/images/mgl ... acing.webp
They have been inboard all season
