2024 Mclaren Formula 1 Team
CMSMJ1
CMSMJ1
Please take this bib waffle to the bib thread - thank you
IMPERATOR REX ANGLORUM
Darth-Piekus
-1
FittingMechanics wrote:
18 Oct 2024, 10:30
It is a breach if they changed it. Problem is that no one can prove they changed it in previous races Just like Option 13 or Ferrari engine.
It is a shame but not a much you can do retroactively (maybe if someone testifies). While I agree in principle you can't punish them without proof, FIA should be able to give some sort of punishment (probably financial one) for devices that can clearly be used to cheat. The way it is currently you can cheat but you need to make sure that it is undetectable without new sensors. Once FIA adds the sensors you stop cheating.
As I am not a steward I have no idea what you have to do to consider cheating. Technically with a loophole anything illegal can be considered to have not enough proof. If you think of it Mclaren was never proven to have used the copied dossier during the Spygate and back then taking information from one team to the other was normal. However that didnt stop Mr. Mosley in almost making a whole team extinct. Benetton while they havent been punished for Option 13, they did get punished regarding the rig. I think its up to the FIA to stop being wussies and start acting like an organisation with rules otherwise they might as well remove every rule and its free for all.
FittingMechanics
FittingMechanics
To get back on team track.
"Norris was optimistic, saying he has more confidence about having a competitive weekend in Austin compared to Singapore where he clinched his most dominant win of the season last month."
When reading the quote I think Norris was saying that last year he wasn't as fast in Singapore (like this year) yet he was better in Austin. So going by that this should be great as he dominated in Singapore 2024.
Quite optimistic from Norris who likes to downplay chances. I think they expect the update to deliver.
Cassius
Cassius
18 Oct 2024, 10:54
ispano6 wrote:
18 Oct 2024, 10:41
How would McLaren end up at their quali height at the end? Does it mean they didn't go as low as possible to account for full weight and acceptable plank wear? You see, this explanation has nothing to do with what Red Bull are doing, and if anything this explanation would imply Red Bull knowingly set up the car to get slower toward the end of the race. I don't see them doing that.
Yes, I think you are right. I got that wrong (it's the other way around). Due to weight, they would start lower than in qualy and slowly rise up to the qualy height.
Red Bull could fine tune that, perhaps starting a bit higher than they would with qualy setup full of fuel, this would put them into a better window while heavy on fuel but at the end they wouldn't be on "qualy setup" like McLaren, they would end up higher than in qualy.
This could explain the discrepancy between qualifying and final stints for Red Bull. For example in Imola, Max qualified ahead of both McLarens by a small margin, he pulled away a bit (7s or so) but at the end Norris was much faster and almost caught him. Given how close their margins were in Q3 it is a bit strange but as always, there could be a number of factors like tyres, temperature or just plain mistakes.
I am just guessing how this might work. But we have noticed that McLaren is a good final stint car this year, usually against Red Bull.
The mental gymnastics to try to explain the last few races with the bib adjustment option is hilarious to read. McLaren has been better at the end of each stint, not just the end of the race. This is due to the balance issues of the RB which crept into their floor since '23 leading to better tyre performance at McL. Also, the stiff RB works when it is low to the ground. When it has to soften the suspension (e.g. in Singapore) the car is relatively high and it loses more df relative to other cars. Hence why early in the race the RB is relatively strong on circuits where it can drive low and hard (e.g Austria) and relatively slow when it has to soften the suspension (Singapore).
FittingMechanics
FittingMechanics
Cassius wrote:
18 Oct 2024, 11:50
Could be. Maybe it's nothing big and Red Bull only used it to make their setup changes quicker. If that is the case great, no question marks over the season and we can continue.
Now let's stop the discussion about the bib as moderators asked us.
hollus
Also a gentle reminder that this is the papaya team thread. If your post is only about the blue cars, there is a caffeine loaded team thread somewhere, you can go there (but please play nice and keep it civil).
¡Puxa Sporting!
Ground Effect
Whatever happened to the Mastercard deal?
Macklaren
Macklaren
Ground Effect wrote:
18 Oct 2024, 16:52
i think that is 2025. will prob be all new livery (though usually they keep livery full reset for change in regs which would be 2026)
PapayaFan481
PapayaFan481
Macklaren wrote:
18 Oct 2024, 16:54
18 Oct 2024, 16:52
I'm not sure you can say that since the livery changed regularly over the years leading up to 2023. Even last year into this was quite a big change.
I'm still hoping that we see a full time return of Chrome next year!!
If I come across as blunt, I apologise, it's my ASD. Sometimes, like an F1 car aqua-planing, it gets out of my control.
Luscion
Luscion
136
SilviuAgo
127
We have some upgrades for Austin, but NO new floor :roll: :
Performance:
- Front Wing: New Front Wing Geometry
- Front Suspension: New Front Suspension
- Front corner: Updated Front Brake Duct Furniture
- Rear Corner: Modified Rear Suspension Fairing
Circuit specific:
- Front Corner
- Rear Corner
- Beam Wing
SilviuAgo
127
MCL38 in Austin
Emag
Emag
137
Luscion wrote:
18 Oct 2024, 18:36
Kind of weird that they had a full month to manufacture upgrades for both drivers but they only bring one.
Could be an intentional choice to compare specs, but still. You would think if you’re confident you want it on both cars. Oscar has to take points away from Max if they’re serious about the WDC.
Developer of F1InsightsHub
SilviuAgo
127
American GP Upgrade Analysis:
McLaren
Andrea Stella’s team have brought the most updates this weekend, with a total of 7 new parts. These feature 4 performance upgrades and 3 circuit-specific ones, marking the beginning of McLaren’s final development phase this season.
The most notable changes to the MCL38 this weekend are to the front suspension and front wing, which are both intended to improve airflow characteristics and increase aerodynamic load.
Mercedes
Mercedes bring 6 upgrades, including 4 performance updates and 2 circuit-specific ones. As reported previously by LWOS, this weekend’s package is significant – featuring a new floor on the W15.
This is Mercedes’ first floor update since the first half of the season.
The Silver Arrows will hope for a significant step forward, having also re-profiled their front suspension to improve airflow through the car. These are some of their biggest changes of the year, and will establish key foundations of their 2025 package.
Red Bull
Red Bull have a relatively small update package this weekend, with just two new components. The RB20 will be fitted with a new floor edge and engine cover this weekend.
These modifications represent the product of intensive work at Milton Keynes to develop a more stable car. After an encouraging race (in terms of drivability) in Singapore, Red Bull are optimistic they can add downforce without sacrificing stability.
Ferrari
no updates
FittingMechanics
FittingMechanics
Alpine looks super similar to McLaren. Whoever designed the livery was having a joke.
Gasly had a spin in T1 and I was sure it was McLaren with red/pink flowwiz on rear wing.
