ArgyrisB wrote:regarding the diffuser discussion.
The primary purpose of the diffuser is to expand air resulting to drop of velocity and therefore increase in pressure. So it creates a pressure potential which will accelerate the flow underneath the car. However in the previous images we have seen that in the area of the diffuser the pressure is lower than the pressure underneath the car not higher as one would except.
What's the explanation, cause i've been confused
Sorry i misread, your confusion comes from the fact that there are 2 two distinct area, the throat or inlet and the outlet.
You say : " However in the previous images we have seen that in the area of the diffuser the pressure is lower than the pressure underneath the car not higher as one would except"
Which is contradictory for you with that :
"The primary purpose of the diffuser is to expand air resulting to drop of velocity and therefore increase in pressure"
Which happend at the outlet, so pressure is lower at inlet end back to freestream at the outlet.
I correlate qualitatively my numerical experiments with real tunnel flowvis and thanks to my very clever tool, more than i am, it is very good !
A Transat chair in ground effect:
The real thing (upper image):
