Mercedes W12
Re: Mercedes W12
mkay wrote:
04 Mar 2021, 22:46
It does look like the W12 is running more rake than the W11?
It's better to wait for the car to hit the track for things such as this, in a studio they can put whatever ride height they want.
Owen.C93
Owen.C93
177
Re: Mercedes W12
mkay wrote:
04 Mar 2021, 22:46
I think every launch thread for every car in the past decade has had the same comment lol
It's usually because shiny floors make the car look higher off the ground.
mkay
mkay
16
Re: Mercedes W12
Owen.C93 wrote:
05 Mar 2021, 00:18
mkay wrote:
04 Mar 2021, 22:46
I'm looking at where the rear floor edge ends with respect to the tyre and tyre rim... and it seems to sit slightly higher than the W11 (look at studio photo)
https://mercedes-benz-archive.com/marsF ... =180339266
HungarianRacer
HungarianRacer
36
Re: Mercedes W12
mkay wrote:
05 Mar 2021, 00:48
Owen.C93 wrote:
05 Mar 2021, 00:18
mkay wrote:
04 Mar 2021, 22:46
... It's worth keeping in mind that the cut-back floor WILL HAVE this visual effect from this viewing angle, just picture the W11 having a narrower floor there, or the W12 with last year's floor, it "stretches down towards the ground" at the back, doesn't it?
raymondu999
Re: Mercedes W12
Theoretically as long as the front wing doesnt hit the floor, they can crank any rake they want on the launch floor 😅
失败者找理由,成功者找方法
Re: Mercedes W12
The covering on the sides of coke bottle area is what catches my interest. It looks either to be a cover to hide something or it is a type of heat resistant covering not seen on other Mercedes powered cars.
FittingMechanics
FittingMechanics
16
Re: Mercedes W12
PlatinumZealot wrote:
05 Mar 2021, 06:46
It's a cover to hide the details.
zibby43
zibby43
Re: Mercedes W12
BestOfDiResta
BestOfDiResta
Re: Mercedes W12
I agree that in the studio they can set ride heights to whatever they want. However I wouldn’t be surprised to see them shift slightly higher than last year when they hit the track. The changes to the regulations are likely to cause greater losses at lower RRHs where floor area is more dominant.
OO7
OO7
171
Re: Mercedes W12
05 Mar 2021, 06:46
If you mean the sides of the coke bottle area just ahead of the rear axle, I think that's just the shape of the cooling exit. Merc for the past few seasons have tended to alternate (depending on ambient conditions and circuit characteristics) between a 'V' style opening (looks like a 'V' from the rear, with the bodywork exit walls creating a gap to the gearbox casing) or a long (horizontally) exit, with the exits beside the gearbox casing essentially closed off. Red Bull have completely closed off this area in their 16B, giving it a very tight rear coke bottle shape.
HungarianRacer
HungarianRacer
36
Re: Mercedes W12
OO7 wrote:
05 Mar 2021, 14:11
[Red Bull have completely closed off this area in their 16B, giving it a very tight rear coke bottle shape.
"Completely closed off" lol, that would make for a bit of a compromise in the drag and cooling efficiency department, don't you think? :) ... I'd like to know what you base this on, as we're (as far as I'm aware) yet to see a single photo/digital render of the RB16B's rear heat outlets, I mean, sure, based on the released pictures the "heat exhaust tunnels" seem to start higher on the sides of the engine cover and have more arch to them than before, but I'm willing to bet the outlets themselves will still be larger than the Merc's, as it's been tradition for Red Bull in recent seasons...
Zynerji
112
Re: Mercedes W12
I always wondered why these outlets are not designed with laminar flow "nozzle" consideration.
Maybe max flow with less drag is just more efficient.
SiLo
139
Re: Mercedes W12
Owen.C93 wrote:
05 Mar 2021, 00:18
mkay wrote:
04 Mar 2021, 22:46
New car launch bingo:
1. It's a reflection
2. Ride height comments
3. Launch car not real car
Feel free to add more
Felipe Baby!
OO7
OO7
171
Re: Mercedes W12
HungarianRacer wrote:
05 Mar 2021, 17:06
It just looks that way from the following, lightened image:
But you may be right. Looking at the image more closely again, I can see there's room (in terms of visual unclarity) to support your observation.
Re: Mercedes W12
Zynerji wrote:
05 Mar 2021, 17:12
I wonder if they try to get them to act as extractors - using the airflow along the outside of the bodywork to pull the cooling air through the car. As you say, getting more air through is perhaps more important than minimum drag - this is an area of the car that is already pretty drag-inducing anyway, so perhaps any drag gains would be so small as to be lost in the "noise".
