Mercedes W17
Lasssept
135
Re: Mercedes W17
tomazy
tomazy
231
Re: Mercedes W17
It seems like the middle part of the rear front wing flap (prat under the nose) does not move when in low drag mode.
HungarianRacer
HungarianRacer
37
Re: Mercedes W17
Interesting, so it seems like the the uppermost front wing flap is pivoted at the rear (opens UP like a classic DRS flap), meanwhile Ferrari has their second and third wing elements pivoted at the front, allowing the assembly to drop BACK when straight line mode is activated...
I can't imagine Mercedes not giving some thought to this area, their two forwardmost flaps are probably already so shallow that there's little drag reduction benefit to chasing the Ferrari route, although, it is still at least two leading edges generating drag vs only one with the later solution.
And then there's consideration to be given to scenarios where there's still steering angle to be applied when straight line mode is already available or when you have to do a sudden maneuver, aero balance will still need to be there (though I cannot see the FIA being generous enough to let them enable it in ANY front grip-limited situation, but we'll see...).
gromajor
gromajor
Re: Mercedes W17
Gridlock wrote:
23 Jan 2026, 22:46
gromajor wrote:
23 Jan 2026, 22:44
that would mean only the third element is mobile, so more drag in straight line.
strange...
If they're running different FWs at different circuits then you'd expect a high-DF draggy wing at Barcelona, right? Which is what they're shaking-down for.
Making such a compromise made sense with fixed wings.
But now, why would they deliberately keep some additional drag on straight lines, when it's not needed, and when it can be removed just by flipping the wing?
They're the only ones to have chosen this solution so far. (We still need to see what McLaren, Williams, and Aston Martin will do)
I'd be a bit more reassured about their performance if I'd see another team do the same.
After, maybe it's a deliberate choice to limit the delta of load on the front tires when transitioning from one position to the other.
Re: Mercedes W17
gromajor wrote:
24 Jan 2026, 16:14
Other possibilities:
(1) They keep slightly more load in order to keep the tires warm.
(2) The movement of the rear flap is designed to stall the two forward elements.
Beware of T-Rex
Re: Mercedes W17
Lasssept wrote:
24 Jan 2026, 14:11
Beware of T-Rex
michl420
michl420
Re: Mercedes W17
HungarianRacer wrote:
24 Jan 2026, 15:59
[i]Interesting, so it seems like the the uppermost front wing flap is pivoted at the rear[/i] (opens UP like a classic DRS flap), meanwhile Ferrari has their second and third wing elements pivoted at the front, allowing the assembly to drop BACK when straight line mode is activated...
Front wing flap must rotate on its front axis (regulation).
sucof
39
Re: Mercedes W17
I think the philosophy of the merc 1 flap solution is that the second flap is in itself quite neutral. And probably they believe that configuration results in something that is more stable aerodynamically, than rotating 2 flaps.
I am sure it is impossible to create a wing flap that is just as efficient and stable in 2 different angles. So it is always a balancing act.
Re: Mercedes W17
It's just like the DRS in that you can choose how to shed your drag. I think we will see many solutions of big flap little flap one flap two flaps.
michl420
michl420
Re: Mercedes W17
PlatinumZealot wrote:
25 Jan 2026, 02:28
I don´t think so. The primary function for the front wing is downforce, closely followed by guiding the air to the rest of the car. Even this two are difficult to manage. They will probably just look how they can reduce the drag best with a solution that fits best for the other two "prime" areas. But I admit, I have no clue how big the drag reduction on a front wing is in compare to a rear wing.
Andi76
Andi76
476
Re: Mercedes W17
Lasssept
135
Re: Mercedes W17
Re: Mercedes W17
Beware of T-Rex
Re: Mercedes W17
Really cool bib region
Brandon has spotted a very nice bib winglet detail
Lasssept
135
Re: Mercedes W17
