McLaren MCL34
Ashwinv16
Re: McLaren MCL34
_cerber1 wrote:
19 Jun 2019, 21:21
godlameroso wrote:
19 Jun 2019, 21:12
That's the steering arm.
But in Canada, he looked different.
https://pbs.twimg.com/media/D8mgFfwWkAAbHzr.png
https://drive.google.com/file/d/13B9UtY ... sp=sharing
He means this part that is similar to Mercedes.
https://drive.google.com/file/d/1bs7dAZ ... sp=sharing
In the Mercedes it is apparently a simple ball joint that is designed mechanically to allow the suspension to dip down a little so for example when turning right the left side goes down a bit allowing the front of the car to stay level with track. Not all teams need this but teams with that raised upper wishbone were struggling with front end grip(Under steering as the upper wishbone joint sent forces in the upward direction and side direction causing Lateral vibration) through medium speed and slow speed corners until Mercedes this year found a way to keep the suspension level in these corners so negating vehicle dynamics deficiency with Aero stability. It's a big reason in Mercedes's up turn in pace. Now teams not running that upper wishbone joint don't need it like Ferrari and Haas for example. Racing point went on an entirely different route to solve that but that i will probably put in Racing point forum.
Or it could just be something they did to the front suspension to stop it from breaking after Canada's rear suspension.
Halo not as bad as we thought
trinidefender
trinidefender
318
Re: McLaren MCL34
godlameroso wrote:
19 Jun 2019, 20:03
Sharnlarry wrote:
19 Jun 2019, 19:39
No they haven’t. Look at pre season pictures
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
Looks like offset wishbones to me.
No one said anything about wishbones. They said pushrod. The point attaching the pushrod to the upright was moved further inboard allowing ride height change through steering lock as well as any other effects.
This will probably primarily help with low speed corners as it can reduce ride height for the front the more steering lock that is applied. That's actually not a small change and I expect that it will take some getting used to concerning car setup.
f1rules
f1rules
634
Re: McLaren MCL34
Great spot,
before
New
M840TR
M840TR
315
Re: McLaren MCL34
If the Pushrod-on-Upright feature works - and it probably will - then this could be somewhat of a game-changer.
makecry
makecry
19
Re: McLaren MCL34
M840TR wrote:
20 Jun 2019, 09:19
Can you hmm.. dumb it down a bit?
f1rules
f1rules
634
Re: McLaren MCL34
williams thought it was important also, they introduced at the last gp, lets hope this can help make the front stronger, will be very interesting to follow. Im pretty impressed with their update rate this year, i have to say.
_cerber1
299
Re: McLaren MCL34
Old wing?
M840TR
M840TR
315
Re: McLaren MCL34
makecry wrote:
20 Jun 2019, 09:34
M840TR wrote:
20 Jun 2019, 09:19
Are you asking for an explanation? If so, then it works by lowering the outer wheel & raising inner one mid-corner. This reduces front ride height and increases tyre contact surface. Therefore more grip.
Btw, Williams introduced the system in Canada and even the beleaguered FW42 improved its performance.
_cerber1
299
Re: McLaren MCL34
Ground Effect
Re: McLaren MCL34
Is it something that can be incorporated on Lando’s car over the course of the weekend, if it works as expected and improves performance?
_cerber1
299
Re: McLaren MCL34
Ground Effect wrote:
20 Jun 2019, 12:10
I hope so.
M840TR
M840TR
315
Re: McLaren MCL34
20 Jun 2019, 12:10
Definitely. It's normal to divide testing programs between drivers.
M840TR
M840TR
315
Re: McLaren MCL34
_cerber1 wrote:
20 Jun 2019, 10:52
Old wing?
https://radikal.ru
Probably to gather data on downforce vs outwash setups
Re: McLaren MCL34
_cerber1
299
Re: McLaren MCL34
