2026 Drama: Alleged engine loophole
venkyhere
43
Re: 2026 Drama: Alleged engine loophole
Arcanum wrote:
03 Mar 2026, 22:40
People just don't like Mercedes. Fair enough. I don't like them as a team either. I particularly dislike Toto Wolf's style. Doesn't mean they've done something illegal.
Agree with you, except for the last sentence. Why did Toto Wolff resist the call for revised testing of compression ratio, when the other 4 PU manufacturers & FIA want the same ?
Stu
catent wrote:
03 Mar 2026, 20:27
Arcanum wrote:
03 Mar 2026, 19:47
catent wrote:
03 Mar 2026, 05:51
catent wrote:
03 Mar 2026, 05:51
In fact, the bodywork dimensions you reference were changed four times between 11 December 2024 and 10 December 2025 (a calendar year). Surely, if the FIA felt this solution was beyond what they intended, they could have told Ferrari as much and modified these bodywork dimensions yet again, to effectively prohibit such a solution. The FIA did not do so.
Mod post - when quoting very long strings please edit according to the points that you are raising; it really spams the thread. People will have read the post multiple times before they get to the talking point.
Matt2725
Matt2725
venkyhere wrote:
03 Mar 2026, 23:13
Arcanum wrote:
03 Mar 2026, 22:40
Could have purely been done out of principle.
The fact the other PU manufacturers have been pushing for a hot only test with no test at ambient should be where the alarm bells are really ringing.
Ultimately a team will push to have the rules changed to benefit themselves or disadvantage their competitors. Regardless, it doesn't mean Mercedes has actually done anything illegal. Apart from those with the knowledge involved, nobody can say with any degree of certainty. The vast majority of the accusations appear to be coming from a place of disliking Mercedes, or wishing the team they support to have an advantage to win the title (for the first time in 2 decades).
FW17
184
One of the main reasons for this mess is because of the removal of in cylinder pressure sensor. FIA now does not have a means of outright banning it on basis of telemetry alone like they did with redbull fuel flow in australia 2014.
Martin Keene
Martin Keene
FW17 wrote:
04 Mar 2026, 17:33
Again, peak cylinder pressure =/= compression ratio.
FW17
184
Martin Keene wrote:
04 Mar 2026, 18:32
FW17 wrote:
04 Mar 2026, 17:33
It is when cylinder cutting moments
atanatizante
133
Jesus
Hoffman900
Hoffman900
242
FW17 wrote:
04 Mar 2026, 18:49
Martin Keene wrote:
04 Mar 2026, 18:32
FW17 wrote:
04 Mar 2026, 17:33
No it doesn’t; you have varying IVC points, you have piston ring leakage, you have varying strategies with the throttle body to control engine braking / airflow through the engine.
Martin Keene
Martin Keene
FW17 wrote:
04 Mar 2026, 18:49
Martin Keene wrote:
04 Mar 2026, 18:32
FW17 wrote:
04 Mar 2026, 17:33
I don't even know what that means, but compression ratio is only one factor in peak cylinder pressure.
Compression ratio is a mathematical value calculated by dividing the cylinder volume, calculated from the bore & stroke, by the combustion chamber volume at TDC. It is a mathematical value defined by the geometry of the engine.
Peak cylinder pressure is based on the operating condition of the engine while it is running.
Lets assume we have an engine with a compression ratio of 16:1, hot or cold, doesn't matter, we are running 20 degrees of ignition advance, 3 bar absolute boost pressure and at sea level, and the PCP is 200 bar, all random scenarios and numbers picked off the top of my head.
Increasing the ignition timing to 22 degrees, changing nothing else will increase PCP, because the combustion process will start earlier in the cycle, thus gas expansion will star earlier, so the engine is being asked to compress an expanding mixture in the cylinder.
Increasing the boost pressure will increase PCP because the mixture is already at a higher pressure before it starts to be compressed.
Increasing altitude will reduce the PCP because the mixture is at a lower pressure before is starts to be compressed, assuming we have not corrected that by increasing boost pressure.
FW17
184
Martin Keene wrote:
05 Mar 2026, 12:11
FW17 wrote:
04 Mar 2026, 18:49
Martin Keene wrote:
04 Mar 2026, 18:32
try calculate the CR when the engine is off throttle
3 bar at BDC of compression 48 bar at TDC, injector not adding fuel
Martin Keene
Martin Keene
FW17 wrote:
05 Mar 2026, 16:08
Martin Keene wrote:
05 Mar 2026, 12:11
FW17 wrote:
04 Mar 2026, 18:49
A compression is nothing to do with the engine is on or off throttle, it is a geometric ratio of the design of the engine.
Have a read: https://help.summitracing.com/knowledge ... 3816/en-us
https://taylorandfrancis.com/knowledge/ ... ion_ratio/
hollus
FW17 wrote:
05 Mar 2026, 16:08
That would look like 16:1, except that it summarily dismisses thermodynamics and dozens of real world effects.
¡Puxa Sporting!
Hoffman900
Hoffman900
242
Martin, you’re waging an uphill battle with this here, sadly, even though you’re on point.
Martin Keene
Martin Keene
I think so, makes me wonder how much other stuff on here people type with such authority is based on similar 'fact' as well...
Hoffman900
Hoffman900
242
Martin Keene wrote:
05 Mar 2026, 17:01
A lot of stuff…
