carisi2k
29
Re: Honda Power Unit
While honda made some miscalculations on the 2017 engine. Mclaren shouldn't escape blame either as their insane push to size 0 obviously had implications for Honda. Good words seem to be coming out of Honda, Torro Rosso and Red Bull about the 2018 Torro Rosso Honda package.
toraabe
toraabe
Mudflap wrote:
10 Dec 2017, 20:27
I bought the autosport magazine and they have a pretty good report on what went on with Honda throughout the year. There are quite extensive Hasegawa quotes - I'll try to summarize the ones I find important.
In 2015 their H recovery was very poor, so for 2016 they increased the turbine size and as a result had to move the turbo up. This however increased the CG height so for 2017 they decided to go for the split turbo. As the compressor housing was now forward of the block, the oil tank had to be redesigned into a mercedes-like crescent shape. Unfortunately this caused all the issues they had in pre-season testing and took 2-3 days to fix.
Now the way I see it, McL would have provided Honda with the oil tank accelerations. Honda would then have tested the oil tank on a shaker rig (I think these are also known as rodeo rigs) to validate the design. I don't think it can be determined from the statements whose blame it was - either McL's for miscalculating acceleration (or not providing any at all) or Honda's for not testing the oil tank correctly.
On the issue of power Hasegawa explicitly states that top end power (at the start of the season) was virtually the same as 2016 while bottom end power was lower. He describes a significant torque hole between 9000-10000 rpm which combined with higher than expected driveline inertia created very strong oscillations during gearshifts. Essentially, the engine side inertia was very low compared to driveline inertia, causing it to bog down under upshifts. As a consequence the driveability was very poor due to low end torque and having to shift at non-optimal engine speeds.
I see Honda as being solely responsible for the lack of engine performance, however in my view McL should take all responsibility for the issue of driveline inertia. It is very unlikely that they had communicated correct driveline specifications and Honda had chosen to ignore them.
Hasegawa then goes on to say that the low speed torque issue was addressed by a change in inlet manifold design (introduced in Barcelona). I suppose this had to do with the poor performance noted in media when testing the complete engine rather than the single cylinder. They also mention altering clutch settings - these I suppose have to do with reducing the clutch preload to allow a bit of slip and alleviate the torque spike.
Finally Hasegawa attributes the MGUH bearing failures to a new 'oil blowing' used for 2017. This is not explained at all but I suspect that oil blowing is just an air line from the 'foam side' of the oil tank that allows the bearing cavities to be scavenged. Unlike the crankcase which can be scavenged without an air line due to blow-by, other cavities typically require a 'breathing' orifice with a restrictor that is adjusted to achieve the required cavity pressure.
These scavenge breathers have been used for a very long time in dry-sump racing engines and are very well understood. I fail to see what could have gone wrong - most likely the oil was not well separated in the tank and made its way into the air line, effectively preventing the bearing from being scavenged? Could the excess oil on the bearing and shaft increase dynamic loads and cause bearing failures ?
Anyway, according to the article, it took Honda quite a long time to understand what was happening and in the end they had to modify the oil tank to stop this 'oil blowing' and increase the size of the bearing.
Unfortunately the way I see it the MGUH failures were entirely Honda's doing.
This explains why they early in the season were shifting at 12,5 k.....way to high
MrPotatoHead
carisi2k wrote:
10 Dec 2017, 22:09
Of course there are good words it's the start of a new partnership and that is what you do.
It's not like Honda all of a sudden has a new engine design that isn't a continuation of what they had in the McLAren this year.
But hopefully Honda will improve coming into the 2018 season.
63l8qrrfy6
63l8qrrfy6
368
MrPotatoHead wrote:
10 Dec 2017, 21:38
This is a dead end. It's impossible to simulate the sustained g forces on any of the existing engine test beds. You can simulate instantaneous but not sustained. And the Honda engineers should know what the g forces are - this was not their first season in F1.
If the people on this forum knew the predicted cornering forces then what excuse do the engine manufacturers have for screwing it up?
I agree about sustained g loads, however CFD simulations are a good alternative to physical testing. Fuel tank and sump slosh have been done to death in both automotive and motorsport - here's an example from Sauber:
https://www.youtube.com/watch?v=-Iyh-S-LGN8
Keep in mind though that longitudinal and vertical g loads are also important and can't be easily predicted without good knowledge of the dynamic behaviour of the car - knowledge that only McL would have.
MrPotatoHead
Mudflap wrote:
10 Dec 2017, 22:19
MrPotatoHead wrote:
10 Dec 2017, 21:38
CFD is indeed used for this. And should have been in this case as well.
So you don't think McLaren shared with them expected loading from the car based on the simulations they already had data from?
Considering how early I saw 2017 wind tunnels models I know full well the teams had full simulation data in hand at the same time based on the same designs.
We need to stop making excuses for a bad job on the engine side.
amho
MrPotatoHead wrote:
10 Dec 2017, 21:38
Although I haven't seen any engine test bed but I can imagine putting an engine on a rotational arm then centrifugal force simulate sustained g forces.
There is no Might or Power except with Allah.
Joseki
Joseki
Hasegawa was doing Honda's interests by not accusing McLaren. He tried to make the partnership last to 2018 because he knew that McLaren was the best possible team for Honda.
Let's be frank: Toro Rosso's chassis has been the slowest of the 3 Renault powered teams for most of the season, both in terms of pure top speed and overall speed. They have two hugely inexperienced drivers, relatively small facilities and the switch was announced quite late. Even if the engine does gets competitive I don't see Toro Rosso being able to outperform Renault or Force India. And we all know that Red Bull is openly flirting with Aston Martin for the future, so that is probably just an option for the mid term.
And let's not even mention what the British press could have said if he accused McLaren!
In reality Hasegawa has been a dead man walking since winter testing. The oil tank issue was beyond ridiculous and triggered a chain reaction that was inevitable.
I feel for the man, he seemed very honest and a team player, but in F1 you have to deliver, and Honda for many reasons never did. Hopefully he planted the seeds for success.
Inviato dal mio Redmi Note 3 utilizzando Tapatalk
63l8qrrfy6
63l8qrrfy6
368
MrPotatoHead wrote:
10 Dec 2017, 22:23
Mudflap wrote:
10 Dec 2017, 22:19
MrPotatoHead wrote:
10 Dec 2017, 21:38
I said I can't tell whether McL have provided the data or if the data was correct. Similarly we don't know if Honda used the data or misinterpreted it. I've not seen anything about this in the press.
When the input of more than one party is required in the design of a component it gets very woolly.
MrPotatoHead
amho wrote:
10 Dec 2017, 22:42
MrPotatoHead wrote:
10 Dec 2017, 21:38
That's about as close as you can get but that wouldn't really be a true dynamic test.
MrPotatoHead
Mudflap wrote:
10 Dec 2017, 23:56
I know, I wasn't saying you said that - just playing devils advocate.
Some of the issues they had would be ok if it was year one - but it was year three... the excuses are pretty thin at that point.
Hopefully year four is great for them and even better for McLaren.
Joseki
Joseki
Personally I liked McLaren Honda more than I would ideally like McLaren Renault or Red Bull Honda, that was the preferred option, so I don't share your view on Red Bull Honda being a better option (mainly because I think Horner and Marko are a bunch of political clowns). Those are all sub optimal options.
bauc
Joseki wrote:
10 Dec 2017, 23:54
You nailed it, the fall of the partnership started with Honda designing a oil tank that can not withstand a hard turn in F1 when the G force is 4 or 5 times higher than normal. After 3 years really?!?! And then they claimed it was an easy fix which was never actually fixed, instead they implemented a solution which was a compromise so they can have the car working ''properly''
bauc
HondaRaceReplica wrote:
11 Dec 2017, 15:25
It would be nice if all the Mclaren "Fanbois" left and we could retuen this thread to technical and positive talk about the Honda Power Unit...You Mclaren guys are already with Renault.....Get on with your lives pls...
A design flaw of a oil tank is a technical issue, which was just put into context that Honda R&D did not come up with a proper redesign just a counter measure to prevent failure during the course of the last season.... that's all.
fellowhoodlums
fellowhoodlums
Oil tank countermeasure, did we ever find out what that was? We find lots of problems (MGU-H bearings is another) and Honda always use the term countermeasures to "fix" it.
Do we know what countermeasures they employed and also, if those same measures compromised performance for reliability?
bigblue
Sorry bauc this doesn't make much sense to me. The oil tank issue seemed to be fixed relatively rapidly. Not sure what "did not come up with a proper redesign just a counter measure" means. As I remember it being reported, the tank was modified to avoid the issue (change in internal baffles ?), and it seemed to cure the problem ? At which point Honda moved on to the many other problems they had to address.
Seems like people are over-analysing the terminology used (yet again). As far as I can see, "counter-measure" means some modification of parts to fix the problem, you can call that a "re-design" if you wish (though that has connotations of a major change), anyway it's just the language Honda used.
