Also, while I don't think we can completely discount that this thing might be controlled somehow, I have to say that I
hope it is not, regardless of how clever such a control device might be. I'd like my team to win on merit, and I certainly don't want to see this blow up into yet another scandal.
Having said that - and eager to shift the talk to some other part of the car, even if it's related - one thing we haven't discussed much is the "little" exhaust over the tail light. I guess we've all taken it's purpose at face value, with perhaps there being some added benefit of providing air directly over the diffuser. But I'll just throw this out for discussion...
This is an area of pretty low pressure, right? And I'm guessing that the pressure there decreases with speed. If so, then could this be used to control a flap or valve, using only the speed of the car as the trigger? Specifically, in regards to the blown wing, could the suction at this point be used to move a flap that would then direct the flow of air from the rear wing flap into this exhaust vent itself (or elsewhere - out of the engine cover slit, for example)? I'm thinking as I'm typing here, which is dangerous, but what the hell.
Taking it one step further, would there have to actually be a flap? Could there be one inlet, but two exits, and depending on the car's speed and the relative pressures created cause the air to flow one way or the other? I guess something like that would only work if the flow of air needed on the rear wing were really
really small, so I guess not.
Oh! Or maybe the driver changes helmets mid-straight, causing the airflow to... Oh, sorry, wrong forum. I'll be over at Atlas if anyone needs me.
