2025 Scuderia Ferrari F1 Team
SoulPancake13
SoulPancake13
Re: 2025 Scuderia Ferrari F1 Team
I am just not convinced the car was raised for plank wear concerns. The team knew it would be a wet weather race... you don't strike kerbs, the wet tyres sit higher than the slicks, and Melbourne is a very smooth circuit. I personally don't see it adding up.
CjC
CjC
Throw this into your mixer Ferrari fans.
2013, McLaren switch from push rod to pull rod suspension and looked rather good in testing. Come the first race and they were pretty terrible (and was all season).
What happened Jenson?
‘We fitted a suspension component the wrong way round in testing so the car ran lower, giving more downforce but it would have worn the plank away and made the car illegal during the race’.
Anybody else seeing similar comparisons?
Just a fan's point of view
SoulPancake13
SoulPancake13
CjC wrote:
19 Mar 2025, 18:47
I find this hard to believe, the alarm bells would have been a lot louder in this case. It also doesn't really fit what little has come out about the setup change. In this formula, "sacrificing performance" as Charles said is pretty much deliberately raising the floor. Why they did that is the question - whether it was bouncing(I personally didn't see any), plank wear, or something else.
ScuderiaLeo
catent wrote:
19 Mar 2025, 17:00
The significant drop-off in pace in medium speed corners essentially confirms they had to raise the car.
I wonder by how much they raised it; the dropoff suggests they had to raise it a lot. Alternatively, maybe they only raised it by a couple mm, but this drastically impacted the operating window.
Both options have bad implications.
If they only barely raised it and it caused such a massive performance loss, that speaks poorly about the car's operating window. Might have a similar problem to the Barcelona package where the car has "pace" but its other issues are so large the drivers can't take advantage of it.
If they raised it a lot and the performance loss is proportional, the question is why did they do it? What is the underlying cause? There would have to be a bigger reason.
For better or worse, we'll have a decent idea of the performance earlier in the weekend because of the sprint. But even if we do really well this weekend (unlikely considering Ferrari's record here, like Seanspeed said) I wouldn't trust it. We don't only need pace, we need consistency.
catent
CjC wrote:
19 Mar 2025, 18:47
It seems this example was the result of a simple error rather than deliberate setup decision.
A component wasn't properly installed, the car ran lower and provided more downforce than it would've if said component was properly installed. Once they realized their error and properly installed the suspension component, the car ran higher.
I get the sense Ferrari made a deliberate setup choice, rather than discovering something was improperly installed.
It would be quite unfortunate and ironic if Ferrari have designed a car with some fundamental suspension flaw/limitation, given the brand new TD is an expert in suspension.
I'm not saying it's impossible but I'm not sure it's likely.
Fluido
Fluido
How many of you think Lewis will beat Lecler this year?
Autobahn303
Autobahn303
Fluido wrote:
19 Mar 2025, 19:21
Can we please avoid that topic? Otherwise this thread will turn into cancer.
I got PTSD from all the endless Leclerc vs Sainz discussions.
Farnborough
Farnborough
125
catent wrote:
19 Mar 2025, 19:12
CjC wrote:
19 Mar 2025, 18:47
I'm skeptical too. Whichever way up the suspension activatis designed pull/push etc, ride height is ride height.
Usually that's going to be set, concisely, by the mechanics in build process for each and every race. Those images of chassis in box jacked up, no wheels, hard gauges bolted to them are for exactly this purpose. They are reference and datum "instruments " to precisely set whatever is demanded of the spec for that event.
Theres very detailed shim stack etc to facilitate this in suspension activating links to tailor each wheel assembly in spite of any production tolerance and pickup location repeatability.
There may be something in it being lifted, but not a mistake in ride height component per sa.
Macklaren
Macklaren
Farnborough wrote:
19 Mar 2025, 20:12
catent wrote:
19 Mar 2025, 19:12
CjC wrote:
19 Mar 2025, 18:47
I don't know how much time you guys spend over in the McLaren forum but this incident is legendary as an example of how much McLaren lost their way. No chance it was repeated
Farnborough
Farnborough
125
I'd not doubt and didn't contest that event in another team.
Much more that with no commonality, apart from the description of "push to pull" in changing things, the two events really don't share anything in tbe way of application between the two "incident "
There's literally nothing to connect these two, except perhaps sentiment.
ryaan2904
ryaan2904
36
catent wrote:
19 Mar 2025, 17:00
In recent years, ferrari have had a car which is good at slow corners but loses out in the fast corner. I think its good that we are good at the fast corners and trying to find performance for the slow ones
CFD Eyes of Sauron
240
Ferrari ran front pullrod for many years. I do not think they made a simple mistake as McLaren did in the past.
We can wait to hear what Vasseur says if asked about Melbourne's setup. I dont think there's any strong evidence yet for the rideheight issue.
I rewatched the onboards for Melbourne. SF25 has a weak front end in the wet. Understeer and no sharpness. It snaps coming out the corners seemingly from the PU mapping. The Mclarens and Mercedes had better low speed drivability. Be it the rear grip or PU, but Ferrari was very chattery and just seemed off the boil coming out the corners. So maybe the team need to look into the engine and throttle maps. Mercedes sound like it charged up and ready to pounce and very smoothe.
As for the drivers and engineers. Lewis and Adami dont seem as conflicting as the media makes things sound when you listen to all their communication. I think they can have harmony.
Lewis seems to concentrate quietly on the job and uses visual cues of the other cars more than verbal info on them. Adami and Lewis need very minor adjustments to each other to click. Adami's Italian accent and Lewis stuffy nasal voice isnt a problem.
What was interesting is that Adami may have been responsible for Lewis losing the spot to Piastri. He threw him off by counting down the gap; something Sainz always asks for. Instead Lewis said he can see Piastri and doesnt need to hear the gap. That threw him and lost a few tenths.
The overtake by Charles on Lewis was Lewis error. He went to cool the tyres on the straight and opened up the outside with the dry line to Charles.
All in all i think both did their best. No driving errors really and they kept it clean.
The car was the limitation with its poor front grip and poor drivability. The drier the track got the more it improved but not enough.
The pit stop error was a major blunder also. They had 2 chances to pit and blew it.
Setup and PU mapping can improve the car. The team can also review the race management and still be in this championship fight.
Lasssept
68
@berrageiz
Fakepivot
Fakepivot
if he joins, would he be under lico or will lico step down from TD role?
catent
If I had to guess, they're chatting about the rear-wing TD.
Who knows, though.
Wache would be a great asset to Ferrari but seems unlikely he joins after a recent promotion to TD at RBR and with Serra having just joined Ferrari (although I'm sure they could rearrange the org chart to accommodate Wache if he wanted to join).
