Sevach wrote:What happened to "stay within the limits of the track" ?
Boring session.
It can be switched on and off by FIA as every other "rule" . Apparently India is a special case:
http://au.eurosport.com/formula-1/fia-d ... tory.shtml
"...it was deemed the crossing the track limit lines would be okay in qualifying.' " "In the drivers' briefing, Charlie said it was okay to run as wide as you like on exits,
but you are not allowed to cut apexes," he said.
It's interesting because we still haven't heard from FIA about Hamilton/Spa and Rosberg/Singapore.
Edit:
It's academic they agreed and it's fine but. OK, I understand 9th going wide is not an advantage, but here - 12th? How is that not gaining when your line is wide, you don't have to slow down and cut here?
Webber: "On one lap I was on the grass and the next time through I was inside the track, and gained half a tenth" But this is BS, he compares clean lap and compromised lap, proper comparison is the same lap and slowing down to stay on that track.
