Sauber C36 Ferrari
roon
roon
412
Re: Sauber C36 Ferrari
I wonder if the vortex it generates get pulled under the sidepod, or follows the topside. While we can think about flow attachment in this context, I also think about the benefit of creating stable, predictable flow structures surrounding the car. While this consumes energy & creates drag, the consistent shapes induced in the flow field should help downstream devices operate more predictably.
bhall II
bhall II
476
I'm almost positive that such flow makes its way underneath the sidepod a bit like this...
Otherwise, I can't think of a compelling reason to maintain an attached boundary layer upon the top of the sidepod.
henra
henra
wesley123 wrote: It's function seems to be very similar to the similar winglets that teams put on the leading edge of the sidepod.
Hmm, I could imagine that it's rather to reduce spillage of the air flow over the side of the sidepods (which you can see nicely on the McLaren FlowViz pic) by creating a low pressure area along the engine cover and thus the center of the car.
henra
henra
bhall II wrote:I'm almost positive that such flow makes its way underneath the sidepod a bit like this...
My idea would be that they try to prevent this. A high energy vortex would create a low pressure area and thereby could serve to keep the airflow away from the sidepod edges.
roon
roon
412
http://i.imgur.com/gkRjVBb.jpg
http://i.imgur.com/a06Xoop.jpg
And if not that then maybe it aids in yaw situations—flow attachment on the leeward side.
bhall II
bhall II
476
Why would you want a low pressure area on top of anything? That's lift.
henra
henra
bhall II wrote: Why would you want a low pressure area on top of anything? That's lift.
When air spills over the sides of the sidepods and is accelerated downward this creates lift. (Newtonian Lift Formula). If you manage to keep the airflow from being accelerated downward and keep it stuck to the center part of the car which doesn't slope downward that much this should reduce lift. On the other hand you are obviously right the vortex itself would create some lift. Would bei interesting to see how that balances out.
bhall II
bhall II
476
I don't see how it would create lift until such air flow leaves the body as downwash.
trinidefender wrote:
bhall II wrote:As others have implied, I think the idea is to move air flow around the sidepods, where it's more useful, instead of over the sidepods, where it would likely contribute to lift. Sauber just seems to be giving it some help downstream.
http://i.imgur.com/V71kiQt.jpg
To add to this, they are vortex generators, the vortex helps the flow to follow the sharp curves of the bodywork with less separation.
Sauber worked out that they need one up there to delay flow separation so placed one there, pretty simple. Nice detail all the same.
That's my view of it. The flow over the side pods will separate and dump turbulent junk in to the space below the rear wing. By using vortices they keep the flow attached around the side pods and keep the flow nice and clean to the rear end.
A little bit of lift here would be acceptable if the overall result is a net increase in downforce (or rather L/D) on the car. Trading off is part of any design process.
dren
226
That's my guess as well. The bat wing used under the nose on some cars generates lift, for its resulting vortexes.
Honda!
motobaleno
https://it.motorsport.com/f1/news/saube ... te-875894/
Also the C36 has an hightened floor in front of the sidepods.
differently from many others, I like this car more than the new renault
bhall II
bhall II
476
Since a mild consensus seems to be brewing around something I sorta said, I just wanna clarify: I see zero reason to take steps to actively maintain laminar boundary layer flow over the sidepod.
If your car is somehow saddled with an adverse pressure gradient in the Coke bottle area, let alone one that's significant enough to cause separation, then your car has issues that are well beyond the control of mere vortex generators.
The whole point of tapered bodywork is to create a favorable pressure gradient that accelerates air flow to the rear of the car.
dren
226
Just follow the gold stripes. Nice jesus piece, btw.
Honda!
bhall II
bhall II
476
Nope.
For anyone, if you were a packet of air at the front of the sidepod, what would your pathline look like as you moved aft, and why?
A hint (again)...
