Ferrari F60
Conceptual
Conceptual
Re: 2009 Ferrari
Roland Ehnström wrote:I'm pretty sure that wouldn't be legal with the 2009 aero regulations.
How so? It could easily be implemented in a much more organic way that would make it almsot a scaling up of the nosehole...
I will do a new mockup when the kids goto bed...
i70q7m7ghw
i70q7m7ghw
49
Re: 2009 Ferrari
Is it mandatory to have a central section to the wing? If you spread the pylons out nice and wide, use an upper element on the wing to connect to the pylons (similar to what Ferrari were running last year) using that element to provide some structural rigidity you could do away with a central section and the lift it creates, no?
Miguel
Miguel
Re: 2009 Ferrari
Scotracer wrote:FFS, a 1991 Mclaren MP4/6 is almost as fast as a 2008 F1 car. It's all a gimmick.
In which circuits? Just imagine how fast would be an F2008 with wider track, 1.1L of aditional engine displacement (approx 1100 BHP), full flat bottom, wider and lower wings and electronic aids. Woaaaa! It'd probably be about 8s faster per lap.
I am not amazed by F1 cars in Monaco. I want to see them driving in the A8 highway: Variable radius corners, negative banking, and extreme narrowings that Tilke has never dreamed off. Oh, yes, and "beautiful" weather tops it all.
"Prediction is very difficult, especially about the future." Niels Bohr
Conceptual
Conceptual
Re: 2009 Ferrari
psst... don't forget the active suspension, and the anti-matter batteries!
djos
115
Re: 2009 Ferrari
Correct, nose holes have been explicitly banned from 2009 onwards.
"In downforce we trust"
ISLAMATRON
Re: 2009 Ferrari
Diesel wrote:Is it mandatory to have a central section to the wing? If you spread the pylons out nice and wide, use an upper element on the wing to connect to the pylons (similar to what Ferrari were running last year) using that element to provide some structural rigidity you could do away with a central section and the lift it creates, no?
Why does everybody keep saying the central section creates lift? from everything I have read the central section has a neutral priofile much like the camara winglets and since the main plane has been lowered towards the road like the old style wings it creates ground effect downforce.
Conceptual's nose design, although a good idea(pending downforce vs drag analysis) is surely against the current rules.
Conceptual
Conceptual
Re: 2009 Ferrari
Can anyone provide the section of the tech regs that specifically prohibit flo-thru nosecones?
And ISLAMATRON, Pat Symonds has stated numerous times that the center section generates lift due to the upwash of the diffusor of the leading car making the center of the front wing of the trailing car create lift. So, by creating lift in the first place, it changes to downforce generation while in the diffusor wake of another car.
ISLAMATRON
Re: 2009 Ferrari
Conceptual wrote:And ISLAMATRON, Pat Symonds has stated numerous times that the center section generates lift due to the upwash of the diffusor of the leading car making the center of the front wing of the trailing car create lift. So, by creating lift in the first place, it changes to downforce generation while in the diffusor wake of another car.
In what way does anything you typed right there make any sense? can someone please translate for me? Imma look for pat's direct explanation, but I dont buy it as of yet. Then again I tried my best to stay away from the aero engineering building while at university.
Shaddock
Re: 2009 Ferrari
I think it may have been lost in translation....
The up wash from the wake of a leading car reduces down force of the front wing of the trailing car, hence the wider lower front wings & higher, taller rear wings this year to combat this.
The centre section would produce lift if it had an aerofoil section or a positive angle of attack. But this is the opposite of what you are trying to achieve.
tk421
Re: 2009 Ferrari
See Below...
Best regards. I guess this explains why I'm not at my post!
tk421
Re: 2009 Ferrari
tk421 wrote:
Conceptual wrote: Can anyone provide the section of the tech regs that specifically prohibit flo-thru nosecones?
I trust this:
And if still in doubt, certainly Conceptual can go to the FIA website and read the regs himself, no?
And this:
Conceptual wrote:
Pat Symonds has stated numerous times that the center section generates lift due to the upwash of the diffusor of the leading car.
ISLAMATRON wrote: Why does everybody keep saying the central section creates lift? from everything I have read the central section has a neutral priofile much like the camara winglets and since the main plane has been lowered towards the road like the old style wings it creates ground effect downforce.
So it seems a car's main wing doesn't produce lift unless behind another car. It seems difinitive that the main plane is, in and of itself, neutral, and if and only if while following another car (as Pat Symonds states), it might create lift...That said, I admit I'm no expert, so I humbly digress! :D
Conceptual
Conceptual
Re: 2009 Ferrari
If you dig, you will find it. He stated that currently while following another car, you lose downforce, and increase drag... I believe that Ogami has called this the overtaking oxymoron. By having a lifting wing (very near neutral) in the center of the wing when this effect happens, it actually causes the front wing to increase downforce while decreasing drag, which is what you want for slip streaming.
Ogami can fix anything that isnt right. I still ahve not found in the tech regs the specific banning of the thru-nose hole, so if anyone can direct me, please do so!
In the mean time, more pics!
axle
axle
Re: 2009 Ferrari
Despite it illegality, I'll comment on that nose...I'd say that would create so much drag that it wouldn't benefit the lap time.
Ferrari's version was about releasing trapped energy/air pressure...this one would create it.
- Axle
xpensive
xpensive
214
Re: 2009 Ferrari
Conceptual, isn't it interesting how you can behold things in different ways?
Is your design a conventional nose with a hole thru itself, of a spoon-shaped nose with a different kind of wing on top?
modbaraban
modbaraban
Re: 2009 Ferrari
Don't think that would work. However it's quite scary if this thing follows you closely. It might bite a piece of yout car off unless you yield :D So I think it would work psychologically.
