My F1 car - LegendaryM
Re: My F1 car
yep it is true, but the single keel will disrupt the airflow under the tub, wich still has to be clean. A big splitter over there withoutt he keel would simply keep better airflow as the air flowing there will move all the way donw the sidepods to the diffuser, where it does generate some downforce. If you wanna keep the arms at the same height, you rather make a twin keel so those walls used for the keels cna move some air too.
Clean airflow is always better for a car, the keel itself and the wishbones will only disrupt the airflow over there, it might not generate downforce, but it is still usefull for the rear end.
ESPImperium
ESPImperium
64
Re: My F1 car
I was thinking that with the zero keel the air flow is so pure, that shurly the V keel could be used somehow to generate downforce.
Im surprised that many teams havnt tried to develop something likt that!!!
Re: My F1 car
there can be generated downforce from it, but it wpuldnt be efficient and it would create more drag then downforce.
LegendaryM
Re: My F1 car
I have made a few updates while i have been on holiday, all regarding the front of the car:
New wing mirror supports, very similar to brawns:
A slightly revised front wing endplate with a hole similar to toyota and renault:
A completely new front wing. The lower plane has 3 elements and the upper plane has 2 large elements. The upper plane is connected to the nose by the placing of a camera housing in a similar place to redbull's new nose.
Also the vertical supports between the nose and the front wing have been made similar to ferrari's so the don't interfere with the flow from the camera housing
Finally I have modified the nose to make it wider and shorter, so it is similar to brawn's. I have also added red bull style humps on the nose
MRVC: Tolo Racing
Conceptual
Conceptual
Re: My F1 car
I would very much like to see some actual renders of this model, especially with some color!
Good work so far. It looks as if it is all made from solids instead of planes however, so it probably won't translate into any type of CFD, right?
Shrek
Shrek
Re: My F1 car
what does the hole in the endplate do?
Spencer
machin
162
Re: My F1 car
I think the body has to be fully defined before the placement of cameras so I don't think this would be allowed.. plus the camera housing would need to be very long to fill the gap within the "exclusion zone" where only the FIA mandated aerofoil section is allowed....
...The car is looking better and better though! Keep it up!
LegendaryM
Re: My F1 car
Quite a large update - completely new sidepods, similar to brawns and a revised lower rear wing element
@machin - ill post and image of the front wing without the camera housing, so you can see where it fits in, also if you look at redbull's nose the camera extends quite far out
EDIT:
MRVC: Tolo Racing
NormalChris
NormalChris
Re: My F1 car
wow looks really good. Do you have an estimate of about how much time youve spent on this so far?
LegendaryM
Re: My F1 car
NormalChris wrote:wow looks really good. Do you have an estimate of about how much time youve spent on this so far?
I dont have an exact figure, but I have been working on it for years on and off.
Small update: Some vertical fins added to the central 500mm part of the diffuser to direct the air to the central 150mm
MRVC: Tolo Racing
LegendaryM
Re: My F1 car
A few small updates;
A revised front wing endplate:
An extra turning vane on the sidepod
A turning vane just below the airbox inlet
Revised diffusers inlets, so it is similar to redbulls and toyotas
A brand new engine cover, with a shark fin which joins onto the rear wing
MRVC: Tolo Racing
ESPImperium
ESPImperium
64
Re: My F1 car
Youre pace of development is just crazy, if you were in a F1 team, id say that youd be about a good thre-quaters to four fiths of the way thrugh the R&D cost now.
Callum
Re: My F1 car
@legendaryM... Can we have a zoomed out view of the current car with all the updates??
LegendaryM
Re: My F1 car
Sorry i haven't posted for a while, I've been quite busy with school work and stuff, but I have still done quite a lot of updates since i last posted;
1. A heavily changed front wing endplate with a hole in, similar to williams' car, an extra turning vane and an updated connecting between the large turning vane and the upper element
2. A revised upper element which is deeper and more curved. Also a brand new nose which is higher, which means the camera housing is now at an angle.
3. The bargeboards now have a jagged edge to induce vortices, the end of the main turning vane is curved at the bottom to direct air around the outside of the front wheel, and I have reverted back to an older wing mirror mount.
4. Basically a brand new diffuser; the outer channels are curved to make a venturi channel, and the central channels droop down away from the centre line of the car, to increase the exit area but keep the central 75mm of the diffuser the same. Also I have added a toyota style vanes on the rear wing endplates to aid extraction from the large double deck diffuser
5. This image also shows the diffuser, however i have completely changed the rear crash structure so it is lower, and with that had to change the rear suspension aswell. This is so more air flows over the lower rear wing element
MRVC: Tolo Racing
Shrek
Shrek
Re: My F1 car
yay its back
Spencer
