danceman wrote:Many good points in replies. Leading me to think short term future might be a petrol/electric car. Smaller engine, could be diesel, driving generator. All drive from electric motors? Most braking by regeneration. Keeping high car weight would not mean unrealistic light weight batteries. This would be driven from the saving in starting fuel weight and smaller tanks. Is this sufficient? Maybe there should there be a minimum mpg leading to a fuel allowance per race to archive this?
For roadcar use, the near future solution will be downsized diesels and petrol engines, a growing number or petrol engines will be equipped with turbochargers and direct injection and a growing number of cars will be equipped with some sort of hybrid technology with increased use of electric engine accesories. It will take long, probably late 2020's until plug in hybrids will have a large market share.
Racing cars with KERS will be classed as 'parallel hybrids', so most of the power will go through a mechanical tranmission. To convert mechanical to electrical and back to mechanical again, as in a series hybrid, serves no purpose in a racing car. That sort of hybrid powertrain is more suitable to say, a city bus.
In racing cars the battery problem can be solved by using flywheels instead. In racing cars KERS power density is the limiting factor, not energy density. The situation is similar with production car hybrids, while electric cars are limited by energy density.
Fuel consumption limits leads to bad racing, it's better to limit the fuel flow to the engine. That way the drivers will go as fast as they can for the whole race. With a limit, the race turns into an economy race instead. Go too fast and you won't finish because the car runs out of fuel.
