Scuderia Ferrari SF90
bosyber
bosyber
45
Re: Scuderia Ferrari SF90
Oh, that article from Mark Hughes - it's out:
When the real world error was replicated in the simulator, a test driver found the car was 0.3sec slower around Barcelona. The implication being that the car has been carrying 0.3sec-worth of mapping error for all seven races. That 0.3sec difference, apparently, pretty much tallies with the discrepancy between simulator and reality the team has been experiencing. Is this the SF90’s silver bullet that Ferrari had despaired of ever finding? Let’s see, but there is a certain suppressed excitement about the combined effect of the correction and the upgrade coming into this weekend.
... well, if they can solve that now, that would really help make the season at least on track, a lot more competitive! (I still think the points-deficit is likely too much to overcome).
bosyber
bosyber
45
LM10 wrote:
21 Jun 2019, 11:15
How were they so relaxed about showing the underside of the floor? :)
Great stuff!
Also, allow me to quote your post in the race thread with the full video, so people can make additional snapshots if they want to.
MtthsMlw wrote:
21 Jun 2019, 11:45
Haha Ferrari mechanics carrying the floor right through the world feed :D
Wait for it
https://streamable.com/7p9ax
izzy
izzy
bosyber wrote:
21 Jun 2019, 12:01
anyone know what exactly "the aero mapping" is in this context? different from correlation? i mean it's not just the correlation between the 60% wind tunnel model, the CFD and the track data? Something that escaped them for 7 weekends, seems weird!
But yes this could be the breakthrough they needed couldn't it, depending how long it takes them to do new parts and get them on the car
bosyber
bosyber
45
The way I read it, in testing/simulating that new front wing, they had some results that were 0,3s better than in other simulations, pointing them to where the difference between expectation and actual on track pace was.
That then matched with what a lap in the simulator for all 7 race-tracks visited in 2019 confirmed (ie. showing them the pace they had, not the pace they thought the should have had) if they used a car that showed the corrected, about +0,3s slower, pace of the car - so, pointing to them having a systematic - but apparently within a somewhat small area, when a change in FW-endplate can show it up! - miscalculation in the CFD, ie. the way the air flows around their car, that led them to design the car that way. I would guess this is something to do with slow speed corners, where they were slower than last year.
So indeed, they hadn't been able to confirm or find this, rather large, discrepancy for some three months at least (well, likely, was there all through winter, but didn't find it in winter testing, and when Australia showed - did it? - that also didn't make someone go 'ah'). But, at least serendipity has lead them to find it now.
I do have to say, having such a large but unexplained discrepancy validates some of their seeming lack of confidence since the start of the season, so let's hope now they know what's there, that helps focus them on getting the car in order.
The new wing looks more STRish out on track.
bosyber
bosyber
45
Also a bit similar to what McLaren is now running, I think, ie. indeed of the same 'family' of front wings as STR have.
izzy
izzy
bosyber wrote:
21 Jun 2019, 12:57
that sounds quite likely doesn't it, but i'm wondering if 'mapping' is significant. As I understand it, that's normally the relationships between a number of variables, i mean as one changes what all the others do, as opposed to 'correlation' which is how closely each variable is consistent across the different real and virtual environments
bosyber
bosyber
45
izzy wrote:
21 Jun 2019, 15:03
bosyber wrote:
21 Jun 2019, 12:57
That too sounds quite likely, though a bit complicated - and if you put it that way, it probably better shows why they weren't able to find it before, only getting there thanks to serendipity now as it's a complicated thing to fish out of the haystack of data.
izzy
izzy
bosyber wrote:
21 Jun 2019, 15:59
Ah there's an article about aero mapping at http://www.formula1-dictionary.net/map_aero.html. It's basically a set of the drag/lift ratios. it says
Aero map will be taken to the circuit by the race engineer. Race engineers can then use these maps to help them choose the best settings for a particular wing on particular circuit. This tells him the most efficient way of obtaining a certain level of downforce or performance using the wing elements he has. If the driver wants more downforce on the rear, it shows him how best to achieve it, and then what angle of flap is required on the front wing to balance this change. It's all there on paper! Map is used to determine the effect of every single change of front ride height, car rake, front wing angle, rear wing angle, gurney flap height and yaw angle on the front downforce, rear downforce, drag and lift-to-drag ratio of the car. Basically, an aero map is aerodynamic data, signature of the specific car configuration, numbers on a piece of paper, or more likely in a computer.
On the track, data aero mapping is used to correlate in real time what the wind tunnel figures say about aero element.
this doesn't really tell us what went wrong exactly, i don't think, but something mathematical perhaps. Anyway hopefully a step in a good direction now they've found it
dans79
267
This is not good news!
https://www.autosport.com/f1/news/14428 ... ce-updates
Vettel:
Asked how the new parts on the SF90 felt on Friday, Vettel admitted: "Not so good, to be honest, a lot of work ahead of us.
"Yeah, [they] didn't bring what we were expecting, so we'll see what we can try and find overnight, to maybe be a bit better off tomorrow."
Binotto:
"Not perfect," he said about the progress.
"I think we brought here some parts which were important for us to test to understand the direction of development.
"We tested a few parts, some of them will be kept on the car for the rest of the weekend so it is not an entire package that has been cancelled or not.
"A few parts will be kept and considered positive, and the ones that have been removed are considered part of our test plan but not intended to be raced for the weekend."
Binotto explained that the team would be keeping the modified brake ducts, plus the new front and rear wings, as well as other updates that were not so visible.
201 105 104 9 9 7
LM10
LM10
122
dans79 wrote:
21 Jun 2019, 20:44
Good news for you, surely.
dans79
267
LM10 wrote:
21 Jun 2019, 21:05
dans79 wrote:
21 Jun 2019, 20:44
No, it's not good for anyone, it will just make the fan base more toxic, the longer they aren't competitive.
201 105 104 9 9 7
https://twitter.com/Vetteleclerc/status ... 31941?s=19
Binotto also said that all the talk about correlation issues is wrong and there are none.
izzy
izzy
Mattia is saying there isn't a correlation / aero mapping issue at all. From espn.co.uk:
"I read that point but it is not true at all," Binotto said. "We do not have correlation issues. So I would say unfortunately [it's not true], because if that would have been the case then maybe we would have solved part of the performance. But it is not a correlation issue and what I read does not correspond to the truth."
Fer.Fan
Fer.Fan
New FW and RW vare used in FP2, right???
It is positive, hopefully they can get more downforce on front axle. It will be interasting to see if new FW will be used in FP3.
