2014 Design
siskue2005
70
Re: 2014 Design
I still don't understand how an asymmetrical nose could bypass the single cross section rule, like lotus and merc?
Re: 2014 Design
Because the cross section is measured at one specific plane. They make one piece end before that plane so there is only one cross section to measure.
siskue2005
70
Re: 2014 Design
oh that is great, thank you
idfx
Re: 2014 Design
idfx wrote:
Blackout wrote:What if you add a vanity panel to it in order to make the nose and the 'U' sape higher?
For example:
http://www7.pic-upload.de/06.02.14/3o5zeyh3f1vu.jpg
liked the idea, I'm developing. thanks for the tip.
I changed a lot. This idea is good?
Thanks
Re: 2014 Design
On the Mcalren.. great work.
Re: 2014 Design
=D>
idfx, are you by chance active in f1, or perhaps an engineer? That's a very awesome render of the mclaren car.
idfx
Re: 2014 Design
Concept - Keel Nose
idfx
Re: 2014 Design
Blackout wrote:On the Mcalren.. great work.
Thanks
used various photographic references of car mclaren and willians. Then I developed the modeling and rendering.
I did some tests and the color red helps in visualization. Can I change this detail.
I made a render with the color orange-papaya with 75% chromium was interesting
idfx
Re: 2014 Design
turbof1 wrote:=D>
If someone has a job offer I... :D
I'm finalizing a new concept. I believe that is outside the rules, but a good study.
idfx
Re: 2014 Design
Concept - Inv. Nose
theWPTformula
50
Re: 2014 Design
Re: Inverted keel.
Really like the design but I have an inkling that this is illegal. I seem to recall that the nose tip cross section must lie between the point above the trailing edge if the front wing main plane (neutral section) and a point somewhere beyond the front wing endplate line. Correct me if I'm wrong.
Lovely renders, too.
idfx
Re: 2014 Design
theWPTformula wrote:Re: Inverted keel.
thanks very much.
Modeled the front steps as following all the rules, then did a 180 degree turn this back and redesigned the parties respecting the limits.
The nose that invert. the black area is the beginning of the nose.
I read the rules, and this approach is quite different and can be discussed and generate new ideas.
I do not know if it's legal or illegal wanted the opinion of you.
Thanks
el-Magico
el-Magico
-10
Location: The number above shows the current temperature
Re: 2014 Design
We could call this the Michael Jackson F1 era... with every race a new/different nose.. :P
Quote of the year: "almost as sickening as the Velcro fluff under Lewis' cap..."
Re: 2014 Design
I dont think that works. The nose tip is considered the most forward part of the crash structure. So you can't assign a piece of crash structure somewhere in the middle and convince the fia that crash structure just got bended in front of the nose tip.
idfx
Re: 2014 Design
el-Magico wrote:We could call this the Michael Jackson F1 era... with every race a new/different nose.. :P
Moonwalker nose ? UHHH !! kkkkK
ps: if the concept is Legal can send suggestion to name.
