2026 Scuderia Ferrari HP F1 Team
matt_b
matt_b
Re: 2026 Scuderia Ferrari HP F1 Team
It would be typical of Ferrari to botch it now when it's looked so good all through testing and this weekend but lets see..
ScuderiaLeo
Leclerc was complaining about deployment in FP3, I wonder if it's the same problem
Also both drivers complained about the radio quality and they can't hear the engineer...
Luscion
Luscion
136
Yea their pace fell off a cliff in Q2, according to Bernie Collins theyre having battery calibration issues
ScuderiaLeo
The gap between #Leclerc and #Russell in this Q2 is purely and simply one of power. #Ferrari makes up ground in all the corners, even quite a bit, but on the straights it loses out by a lot. 10 km/h on the back straight, another 10 at the braking zone for Turn 11, and anyway you can see it clearly from the top of the graph.
f1Follower
f1Follower
Mercedes has a superior engine or ICE. We will come to know more about it post 1st June where the tests kick in and see if it's trick or genuine
Also Race Day it's going to much hotter than Qualifying so both engine and Aero will be tested
dani5549
dani5549
-1
So we absolutely need the rear wing if the 5km/h advantage is real.
Luscion
Luscion
136
dani5549 wrote:
07 Mar 2026, 08:06
i still think theyre having battery issues, their pace has fallen off a cliff
yup, drivers complaining about it
f1Follower
f1Follower
Australia is also a power centric circuit which shows Ferrari and others lag to Mercedes on engine side
ScuderiaLeo
They keep complaining about the charging... could it be a software issue?
f1Follower
f1Follower
Luscion wrote:
07 Mar 2026, 08:15
dani5549 wrote:
07 Mar 2026, 08:06
It's a calibration issues.
wickedz50
wickedz50
f1Follower wrote:
07 Mar 2026, 07:58
Add the RBR FORD power train ICE as well, both used the same compression loophole, Merc may be a bit better than RBR FORD, creating something original and vs a copy is the current difference in performance.
Luscion
Luscion
136
what a shame, battery absolutely screwed them, ah well
matt_b
matt_b
Battery stopped them from showing their true pace, but its typical Ferrari to run flawless all weekend in every practice session, then when the chips are down they have a problem.
aberracus
aberracus
I feel cheated… Ferrari car and PU are good. Merc is cheating but why Merc clients are not benefiting so much ?
edu2703
edu2703
37
P4 and P7. We started this season in the same way we finished 2025...
