McLaren MCL34
Xero
Re: McLaren MCL34
604gtir wrote:
25 Jul 2019, 03:57
Emag wrote:
24 Jul 2019, 15:58
Seems like the POU suspension is not present here. At least not in both cars. It also looks like the bargeboard upgrade they introduced back in Silverstone worked like expected since they have brought it again here.
it would likely need a revision in the rear suspension as well to work in conjunction with the different front geometry
I agree, it's been exploratory uses so far with next years car in mind. Would also throw away all the knowledge and setup work they currently have with the front end, probably not worth risking in their current situation.
M840TR
M840TR
315
Re: McLaren MCL34
At McLaren, we did not notice anything new at first glance.
AMuS
_cerber1
296
Re: McLaren MCL34
On the second photo can I see POU?
martinbeiker
martinbeiker
Re: McLaren MCL34
_cerber1 wrote:
25 Jul 2019, 18:11
I don't think so
Emag
Emag
137
Re: McLaren MCL34
I don't think so. Last time they tested the suspension, the lump was quite big and obvious. Anyway, I don't think there are new parts for Germany. When asked by AMuS, Andreas Seidl said that they are going to bring new parts for Hungary, not Germany.
Developer of F1InsightsHub
M840TR
M840TR
315
Re: McLaren MCL34
_cerber1 wrote:
25 Jul 2019, 18:11
It's possible but the photo is too vague. Let's wait for better ones.
Ground Effect
Re: McLaren MCL34
I wonder what parts will be on for Hungary. Maybe the tests run with the new suspension were in preparation for 2020? A few of the midfield teams have fairly substantial upgrades.
_cerber1
296
Re: McLaren MCL34
M840TR
M840TR
315
Re: McLaren MCL34
New heave damper?
roon
roon
412
Re: McLaren MCL34
M840TR wrote:
26 Jul 2019, 15:31
New heave damper?
https://i.imgur.com/ts16Lp4.png
The left side (driver's) of it looks plastic or painted.
Labels say (from left to right):
--right hand right hand
--198 ZOG
--300 SP 2 PRE 061 S...
Re: McLaren MCL34
Combined heave damper, spring and fluid inerter all in one package looking at that.
Re: McLaren MCL34
PhillipM wrote:
26 Jul 2019, 19:47
A shock absorber spring ? They're gonna be pissed that picture got out. we've not seen under there since the S-duct was removed.
martinbeiker
martinbeiker
Re: McLaren MCL34
diffuser wrote:
26 Jul 2019, 20:08
PhillipM wrote:
26 Jul 2019, 19:47
I think we saw under there in Monaco FP3, when they adjusted Carlos' torsion bars.
M840TR
M840TR
315
Re: McLaren MCL34
PhillipM wrote:
26 Jul 2019, 19:47
Interesting. Looks like the spring is only present on the left side which is colored. It's possible they're trying to treat both wheels differently maybe based on the stress load each side experiences.
Re: McLaren MCL34
You'd only need it on one side, it's a heave element #-o
Looks like the inerter on the right and preload adjustment for the spring on the left - be interesting to see if they actually use that tommorow as it looks more like a unit used for quick setup changes before building up a lighter one with fixed settings as is usually used.
