Fight for a podium at Bahrain and maybe if the setup is good fight for win at Jeddah
Farnborough
Farnborough
152
09 Apr 2025, 14:22
In reality, we do have no idea about pace that's coming here.
Logically, there's more apparent understanding advance from RB over those first few races than others seem to have acquired. Specific attributes here thuoczn be very narrow in exactly how it brings pace.
Definitely interesting to see the stats once they start running,, temperature likely to show quite different than test though. Ultimately its all up in the air until the fuel comes out and the engines get wound up.
venkyhere
43
09 Apr 2025, 10:30
How come in 2023 they always had cold tires that were slow to go to temperature , and in 2024 and 2025 they always have tire overheating? What is the technical change that occurred and why can it not be reverted?
In 2023, each weekend GP would tell Max about the tires being cool and then a few laps into the race tell him when the tires were “ready”. From the very first weekend in 2024 this never happened again. In fact, Max had been reporting that the tires were already too hot often halfway through the outlap! This kind of message was reported in so many free practice sessions.
How is such a change possible? What changed?
I am inclined to set the scenario from a high school physics perspective. What governs 'tyre temperature' ?
1. size and geometry of contact patch
2. flex/unflex vertically and laterally
3. amount of scrubbing
4. amount of heat imparted/removed
5. amount of torque exerted
6. on top of this, air temp and track temp.
What factors influence 1-5 ?
Tyre pressure, rubber compound, force exerted on contact patch (aero-downforce, spring/damper rates), amount of contact patch 'compressing'/'twisting' from subjective driving style via teering/pedals, geometry of wheel alignment (toe, camber, scrub radius), brake duct design and aero design around the areas near the tyre, PU setting alongwith deployment strategy (engine mode, gear selected, diff settings) and brake pressure.
In other words, it looks like an engineering version of a tightrope walk while fighting a chilly wind (environment) while handling a phone call from the spouse (the driver inputs). I will be surprised if they make a change anywhere on the car, and the tyre temp (and thus it's life) is not influenced. The 'art' of designing the car and setting up the car for a specific track, is to 'see the influence of these factors clearly' and account for it in the design/setup in way that keeps the tyre temps 'in the good window' for the rubber compound + min air pressure (chosen by Pirelli, external restriction), for each particular track for specific weather conditions.
venkyhere
43
Sergej wrote:
09 Apr 2025, 08:28
venkyhere wrote:
09 Apr 2025, 05:31
A nice video demonstrating Norris' sharpness and Verstappen's awareness :
https://www.youtube.com/watch?v=Ym_41isdim8
So Norris almost risked speeding in pitlane to try to overtake Max...on the grass :mrgreen: not sure I would call it "sharpness"
I was talking about 'sharpness' specifically in reference to how accurately he removed the pit lane delimiter in relation to the line on the tarmac, removing the 'margin' these drivers usually keep.
Vettel165
Also pirelli is bringing the hardest tyres for Bahrain GP. We will see what that means.
Vettel165 wrote:
09 Apr 2025, 18:17
Same as last year, but last year's car preferred the C3 at this track. This year's car prefers the harder ones ̶(̶C̶4̶,̶ ̶C̶5̶)̶
(C1, C2)
Beware of T-Rex
09 Apr 2025, 18:37
Vettel165 wrote:
09 Apr 2025, 18:17
Same as last year, but last year's car preferred the C3 at this track. This year's car prefers the harder ones (C4, C5)
you've jsut got the compoundds the wrong way around. C1 hardest, c5 softest. But yes: fortunately this car likes hard compounds. Likely our end of race pace could be decent again, but we'll get demolished in the early stints again by McLaren. Maybe a late SC please? :P
Paa
09 Apr 2025, 18:39
Is there enough evidence to support this?
I only remember such behavior from China main race. But we also saw Red Bull being slow and tyre eater with low fuel in China sprint. Then Red Bull seemed to have pretty consistent relative pace to others across the stints in Japan.
So I would say it is inconclusive at best. Probably mostly depends on how they manage to set-up the car, which seems to be a hit or miss at the moment.
(I did not mention Australia, as it was wet and chaotic
f1isgood
f1isgood
Paa wrote:
09 Apr 2025, 19:08
09 Apr 2025, 18:39
I think the behavior is consistent with hard compounds and low fuel. Wasn't China sprint with mediums?
09 Apr 2025, 18:39
09 Apr 2025, 18:37
Vettel165 wrote:
09 Apr 2025, 18:17
Yes, the tire thing is a mistake. Any sort of late race SC benefits RBR. We have seen this in Australia and it would have been the case in China (would have beaten Russell imo).
Beware of T-Rex
f1isgood
f1isgood
10 Apr 2025, 03:12
09 Apr 2025, 18:39
09 Apr 2025, 18:37
China going too slow in stint one was maybe a bigger issue, only in hindsight. No one foresaw that pace in the last stint.
https://www.the-race.com/formula-1/the- ... r-f1-team/
The Race suggests that the Imola upgrade package will take further steps away from the 2024 rb20 concept and will aim to widen window, add downforce and improve tyre management.
The RB21, so far, has appeared visually similar to its RB20 predecessor. However, a major upgrade package is expected soon, marking a more significant departure from the 2024 concept.
The engineers, led by Pierre Wache, hope that these changes will ease the learning curve required by the car. Verstappen himself has voiced frustration about struggling to find a comfortable set-up quickly on race weekends, a rare admission from the otherwise dominant champion.
Should the updates succeed in broadening the car's operating window, they may offer a lifeline to Red Bull's embattled second seat. Until then, it remains Verstappen versus the field - and sometimes, even versus the car.
The upgrades that will arrive, in addition to having the goal of making the car easier to understand, will try to increase the downforce and improve tyre management, especially in hot temperatures, where the car was shown to struggle last year.
Racing Bulls shares a Red Bull mechanical base (gearbox, engine and suspension), and the VCARB 02 has proven to be a great car. So could Red Bull find some solutions in-house?
Verstappen ahead of Bahrain
"The tyre wear will be more serious," Verstappen told RacingNews365 among others. "In the first stint in Australia we were destroyed, mainly by overheating. The same was true for China and also in Japan it happened to a certain extent. You just couldn't overtake. Lando Norris closed in on me at the end of the first stint in Japan. I knew that was coming, so I drove my own pace. The asphalt temperature was just a lot lower. That helped us."
In Bahrain it will only be very hot, Verstappen sees. "We drive in the evening. It cools down a bit, but it remains hot and aggressive asphalt. On paper that is not ideal for us compared to McLaren if you look at this season. It is up to us to find improvements in the behavior of the car, also with the tires. It is not good enough at the moment, but we know that."
I wonder what will happen with Dan Fallows. Maybe he returns to Red Bull. Red Bull once fought very hard for him not to go. They would benefit from a fresh perspective on the issues. Some people just don't gel in certain places. James Allison never made it happen at Ferrari.
Beware of T-Rex
The discrepancy between simulator and reality is also currently raising eyebrows at Red Bull. Teammate Yuki Tsunoda had already said in Suzuka that the Red Bull can be driven very differently in reality than in the simulator. Asked if that's the same for him, Verstappen refers to the Japanese: "There you have your answer."
"Sometimes it's better, sometimes worse - depending on the weekend," he says. This was particularly noticeable in Suzuka: "In the simulator, you can somehow make the car slide a little more naturally. But if that doesn't work in reality, you're more restricted."
Another problem is the extremely narrow performance window of the current Red Bull. "As soon as you want to get the maximum out of the car, the window is very narrow at the moment," Verstappen explains. Although it is not tighter than last year, "but it is not necessarily bigger at the moment. We definitely have to find more."
On the positive side, however, Red Bull often makes progress over the weekend - a circumstance that could be observed especially from Friday to Saturday. "That depends. Sometimes the balance is a little better, sometimes it's more off," Verstappen said.
Often the set-up is not optimal at first: "Most of the time it has been wrong so far because the car reacts extremely sensitively to small changes."
That's why training continues to play an important role in the development process. "Of course you want to be fast and do well, but sometimes things have to be tried out and understood," says the Dutchman.
The goal is to start the weekend in a more stable window if possible - something that can be achieved in Bahrain could at least be favored by the track layout. "I think it's going to be a bit more stable by nature - just because of the layout. There aren't that many extremely fast corners."
https://www.motorsport-total.com/forum/ ... 21&t=95050
I think the drivers understand that Red Bull need to try things to understand more.
Beware of T-Rex
