120,000 watts is the limit and it equals 160 hp in an f1 car.raymondu999 wrote:KW? What's that?
It doesnt have to be that many 'devices' actualy.Scuderia Nuvolari wrote:120,000 watts is the limit and it equals 160 hp in an f1 car.raymondu999 wrote:KW? What's that?
If they would allow it you could match and exceed any boost that the turbine puts out. There is a jolt limit per lap.
Please, just send me a check for the money they will spend for equipment to just monitor all these devices.
As ever, it all depends upon circumstance and conditions. Back in the turbo days, the oversteering Keke Rosberg could not hold a candle at McLaren to the understeering Alain Prost – and for John Barnard, the team's technical director of the time, the reason was very simple: "Alain would set the car up in a way that to any other driver would feel like it had massive understeer, but he had a way of getting the car into the corner early [with his overlapping of braking and cornering], which for a turbo was fantastic, because it meant he could get early on the power and we could give him some traction. Keke, by contrast, was last of the late brakers and really liked to turn the car very quickly. To do that you need a set-up that's a bit light on rear grip – and that just wasn't the way with these cars because it meant you didn't have the traction to use all that huge power."
Tommy - surely drivability vs peakiness would bear a closer correlation to torque deliveryTommy Cookers wrote:MO very non-peaky, above 10500 rpm the fuel supply rate will not increase, so the power curve will be unusually flat
the turbo will be driven electrically as necessary to keep it up to speed
the fuel supply rate falls below 10500
To memory, the 2014 powertrain calls for 8 ratios, nominated at year start, which stays all the way until the last round, without change. The flat power curve makes it possible as the top speed will pretty much be drag limited and basically the same regardless of the gearing IMO. So in Monaco you might top out at maybe high 6th/mid 7th gear, and Monza you'll be knocking on (but not touching) the limiter in 8thcurrently the teams arrange (for each circuit ?) from a pool of 30 overall ratios available, the 7 best suited to the circuit
from 2014 the pool is only 8 overall ratios available, ie the same 8 overall ratios in the cars at each and every circuit
and the drivers will just use the 6 or 7 best suited to the circuit
unless this rule is dropped too, like the 2014 aero rules
The hybrid turbos will not be peaky at all. There will be no lag and the drivers should ideally not even realise how much torque comes from the engine and how much comes from the electric power unit (MGU-K).raymondu999 wrote:Does anyone know how peaky, at least in theory, these new gen turbos will be? Someone brought up to me that the old turbos were peaky and that's what made them so spectacular to watch.
The regulations demand that both sources of torque are controlled by one throttle pedal. It will be 100% fly by wire like the commercial jet liners today. The throttle is fly by wire already in today's engines but it controls only one source of torque. In 2014 it will always operate in dual torque mode.5.5 Torque control :
5.5.1 The only means by which the driver may control acceleration torque to the driven wheels is via
a single chassis mounted foot (accelerator) pedal.
5.5.2 Designs which allow specific points along the accelerator pedal travel range to be identified by
the driver or assist him to hold a position are not permitted.
5.5.3 The minimum and maximum accelerator pedal travel positions must correspond to the
minimum and maximum available torque with the currently selected power unit torque map.
IIRC the Williams Honda was a dog when Rosberg was the lead driver, but was transformed when Mansell was addedraymondu999 wrote:Does anyone know how peaky, at least in theory, these new gen turbos will be? Someone brought up to me that the old turbos were peaky and that's what made them so spectacular to watch.
Also, here's another interesting tidbit from Autosport about the old turbo days:As ever, it all depends upon circumstance and conditions. Back in the turbo days, the oversteering Keke Rosberg could not hold a candle at McLaren to the understeering Alain Prost – and for John Barnard, the team's technical director of the time, the reason was very simple: "Alain would set the car up in a way that to any other driver would feel like it had massive understeer, but he had a way of getting the car into the corner early [with his overlapping of braking and cornering], which for a turbo was fantastic, because it meant he could get early on the power and we could give him some traction. Keke, by contrast, was last of the late brakers and really liked to turn the car very quickly. To do that you need a set-up that's a bit light on rear grip – and that just wasn't the way with these cars because it meant you didn't have the traction to use all that huge power."
agreedraymondu999 wrote:Tommy - surely drivability vs peakiness would bear a closer correlation to torque delivery
I assume that you are aware that the 2014 cars will have two MGUs.raymondu999 wrote:Hang on - so the MGU will be delivering torque all the way through the throttle pedal travel? Tuned, I presume, for whatever circuit you're on? (obviously the MGU will have different levels of available energy in Monaco, vs say Monza)
No lag - are they using the MGU to keep it spooled or something? So the boost will be there throughout the entire range?
Thanks for the info in the bearings, I always assumed that plain bearings were unbeatable in a turbo. I was wrong.bigpat wrote:Turbo technology has come on leaps and bounds since then. Back in the turbo era, they used to be plain journal bearing turbos, where now, ball bearing cores spin up much quicker. Also, the aerodynamics of turbos are much more advanced, with broader power bands ( boost range).
Also now road and race cars used variable geometry turbos, where you get low speed response and top end power in one. Most famously, last years' Le Mans winning Audi R18's were equipped with V/G turbos, so I can't see lag being an issue in 2014...
5.7.1 With the exception of devices needed for control of pressure charging systems, variable
geometry exhaust systems are not permitted. No form of variable geometry turbine (VGT) or
variable nozzle turbine (VNT) or any device to adjust the gas throat section at the inlet to the
turbine wheel is permitted.
