Rear crash structure, a closer look.
Mystery Steve
Mystery Steve
Re: Rear crash structure, a closer look.
I just took a second look at the pictures and realized I hadn't noticed there are two different orientations of the honeycomb. To be clear, I was referring to the inner-most section where the hollow cores are oriented longitudinally with respect to the car. The two outer-most layers of honeycomb are for additional bending strength, similar to the honeycomb core used in the rest of the monocoque. It's interesting to see that there are essentially two honeycomb sandwiches used.
The goal with the crash structure is to absorb as much energy as possible without transferring it to the car and driver. Ideally, the outer two layers would absorb just enough energy so that the inner core doesn't get annihilated and can still perform its intended task. I guess the engineers calculated that the 3 layers of carbon layup, along with their 2 accompanying honeycomb layers, was just enough to be able to take some of the load off the inner honeycomb core while still not transferring too much energy to the driver.
bhall
bhall
244
F1snake's Honda RA107 from his Flickr photostream:
232
Could the threads have been molded?
hardingfv32
hardingfv32
Brian.G wrote:here is where the piece was taken from,Image
Are these inserts two pieces, a threaded section and an alignment sleeve?
Brian
Brian.G
Brian.G
334
Yes, two pieces.
Brian,
If you think you cant, you wont, If you think you can, you will
thisisatest
thisisatest
i'm not grasping how the alignment sleeve functions. could someone draw it out, or otherwise explain it? it IS a threaded insert for a bolt to thread into, right? or does that piece function as the screw itself?
hardingfv32
hardingfv32
thisisatest wrote: it IS a threaded insert for a bolt to thread into, right?
They are using a shoulder bolt. A bolt with a precisely machined shaft OD that makes for a very precise fit with the sleeve. Provides reduced play or movement in the joint and stronger, in shear, joint for a given size of bolt. .
Brian
Brian.G
Brian.G
334
Bumped for user Billshoe.
BG
