Forward Roll Hoop
N12ck
Re: Forward Roll Hoop
Just_a_fan wrote:Silly idea in the first place and I note that the tyre hit the leading edge of the roll hoop mounting plate before hitting the hoop itself so perhaps they need to check the results carefully.
I could see a single blade type device being placed in front of the cockpit without too much problem for the driver - they have aerials and pitot tubes there already in some cases. But this sort of frame is just daft.
Smacks of the FIA wanting to look like they're doing something whilst knowing that nothing will come of it.
with my idea it would create no obstruction to the drivers view (windscreen), it would look good, and it would stick with the f1 car 'look'
Budding F1 Engineer
flyboy2160
flyboy2160
84
N12ck wrote:...
with its very high grazing angle and curvature, the driver won't be able to see as accurately through your 'windscreen' as it is now unobstructed (save for the helmet visor.) the thicker the windscreen, the worse it will be.
N12ck
flyboy2160 wrote:
N12ck wrote:...
Its just a representation of the idea, the windscreen could be vertical, could be slightly less sloped, could be higher, I think the windscreen idea is more viable than a huge roll hoop infront of the driver.
Budding F1 Engineer
SiLo
139
I think you're never going to remove the danger for racing and the drivers understand that, if you wan't to stop this sort of stuff happening make the car's completely enclosed and turn them into le mans prototypes.
Felipe Baby!
MIKEY_!
Forward roll hoop is a bad option, go for a military grade screen that looks like a late 80's screen but a little taller coupled with a low nose.
N12ck
MIKEY_! wrote:Forward roll hoop is a bad option, go for a military grade screen that looks like a late 80's screen but a little taller coupled with a low nose.
like the mclaren m23?
Budding F1 Engineer
MIKEY_!
More like mp4/4 :)
N12ck
MIKEY_! wrote:More like mp4/4 :)
Yeah I agree :)
Budding F1 Engineer
N12ck
I think this is the idea we are looking at :
Budding F1 Engineer
