Crucial_Xtreme wrote:Maybe I didn't explain myself well enough. I get what you're saying mate, but if you look at the full page link I posted you'll see his comment about the Ferrari wing and how complex it is. Well I take that to mean towards the end plates where the 6 planes are. I'm figuring that's what he's saying is complex but that part of the wing is not on the Y250 axis correct, so I don't see what he's talking about in relation to Ferrari's "complex" FW and controlling the Y250 vortices.
So a quick recap:
The centre 500mm of the front wing is mandated to a specifc profile.
This leads to two separate drag inducing vortices 250mm from the centre line.
These then have cascade effects to items such as the floor and other areas of the car that reduces their effectiveness.
We all got that bit from the Y250 sidebar comment on the RaceTech article.
Just my guess from thinking about it (for 5 minutes):
If the Y250 vorticies could be effectively moved away from the centreline further to avoid turbulence under the car and around the sidepods, then you may be able to do this by pressure changes through shaping and direction of the airstreams away from the centreline.
The wing end plates are to direct flow around the tyres, but they can also be used to create an influential low pressure area on the inside portion of the wing area post flow by pulling air away from the open area between the Y250 line and the inside of the tyre. If you can reduce the pressure then the Y250 vorticies may be moved enough to help reduce their disturbance effect.
So if you can drag the voticies away from their normal flow direction by inducing a low pressure area next to them moving them away from their normal flow path (similar to how the "Coanda Effect" is used to drag exhaust flow away and direct it away from its normal flow path) you can either use other voticies to reduce their effect, remove flow disturbance from under the car to increase downforce due to smoothed flow or used the voticies for benefit in some other fashion/area.
This means the balancing of many influences at the outer edges of the front wing to get the desired effect of:
1) routing air away from the tyre
2) reducing pressure in the Y250 to inside tyre area
3) managing flow to the floor
4) managing flow over the tyre
5) managing flow into, over and around the sidepods.
As there are so many elements to consider, the wing shape is extremely complex and needs to account for the various interactions of the many flow variables around the area behind the wing.
Due to the area and profile of the front wing in the Y0 to Y250 distance of the horizontal plane being regulated, you need to mange the flow from the Y250 through indirect methodologies which create cascade effects to affect flow in other areas. Its a trade off but as has been seen can have significant effects and benefits.
My read on what was said is they are trying to not only reduce the drag from the Y250 voritices, but their influence on other areas like the floor which leads to the diffuser, around the sidepods which leads to the rear wing, getting the front wing to work efficiently in the first place etc etc.
As the front wing is the first thing the air interacts with on the car, then you must look at its entire effect as a holistic system as how the air comes off the front wing will dictate to a large extent how almost every other aero effect will perform.
Never approach a Bull from the front, a Horse from the back, or an Idiot from any direction
