olefud wrote:Temperature alone also has a significant influence. Air (referencing the case of brakes) increases its viscosity with temperature. It is much “tackier” at 1200 or 1800 degrees F than at ambient. At such temps it becomes a thicker, more adherent boundary layer and displays enhanced Coanda effect. Thus, if the heated plume is properly ducted, it can attach to and direct larger quantities of ambient air –which IMO is one of the objects of utilizing the heated exhaust plume.
Your comments are appreciated. I can almost see the wheels turning as you developed the subject.
Need to think about this one a lot more so this is me thinking out load.....
Current F1 “Coanda exhausts” are trying to replicate the sealing of the diffuser area by using high energy vortices from the directed exhaust plume to create an "air wall". The energy they use to create these vortices and maintain the "air wall" integrity is the kinetic energy or velocity of the exhaust plume. The higher the velocity the greater the energy of the vortex created and higher the integrity of the air wall.
So, while I absolutely agree temperature helps with directional flow attachment and as such is an advantage for increasing the effectiveness of the Coanda exhausts in directing the exhaust plume to the diffuser interface to overcome the higher exhaust tip placement, I'm not positive it substantially aids in the actual replication of the diffuser sealing.
So, the basic question is, does a higher temperature gas stream assist with the actual sealing of the diffuser through either aiding vortex creation or increasing air wall integrity or does it only assist with maintaining flow attachment, stream integrity and general velocity in getting it to the diffuser interface?
IMO, the gas temperature is now only such an issue as it aids gas viscosity and the exhaust plume needs to maintain flow attachment to reach the diffuser interface using the Coanda effect.
Once there, the thermal energy of the gas has little bearing on the ability to create the required vortices or increase their integrity as this relies on the use of the high kinetic energy in the gas stream to create and maintain vortex integrity against the outside pressures influences such as tyre squirt and the higher pressure air outside the diffuser bleeding into the lower pressure created. Also, much of the gas temperature has been lost by the time it reaches the diffuser interface to the effects of convection, advection and expansion.
So the heated air from the brakes may have high thermal energy, however it has low kinetic energy, as this is generally limited to that of the forward movement of the car (due to drag considerations and the assumption that the designers would not want to substantially increase effective drag ), which ranges to a maximum of approximately 315kph (which equates to approx. 195mph or 87.5m/s or 287ft/s) but will generally be much slower with average speeds around 225kph (140mph or 62.5m/s or 205f/s).
Additionally, substantially elevated temperatures bring with them other associated issues with the burning, charring or melting of surrounding suspension and bodywork components as well as possibly affecting their structural integrity. To negate the temperature effects you'd have to either increase weigh through insulation or larger mass components or change their materials altogether to survive the elevated temperatures. Standard carbon fibre constructions do not typically like 1100C plus temps and may require titanium ducting and components or basalt based fabrics and specialist resins. Both are generally heavier and if use in suspension will increase the inertia of the suspension systems.
Exhaust gases exit the exhaust tip at approximately 540kph or 150m/s and so has much more kinetic energy. As such, once it reaches the diffuser interface it has a greater ability to effectively seal the diffuser across the various vehicle speeds than the variable and lower energy plume from the possible brake system. Attempts to increase the air speed of the brake plume would result in a trade off for increased drag.
The diffuser can become effective at much lower speed than the average so having the higher kinetic energy exhaust becomes an even greater advantage if you can use it to “drive” the diffuser as well at lower speed.
So to my thinking, ducting the very hot but low kinetic energy brake plume to help drive the Coanda exhaust may help with flow attachment to some degree it would likely not increase the effectiveness of the sealing of the diffuser. It may help slightly to drive the diffuser through the expansion and cooling of the brake plume if it could be directed into the right area, however without a high kinetic energy it will only ever match or be lower than the vehicle speed due to other considerations which brings my thinking to the next set of variables:
1 ) induced drag from ducting and flow restriction to channel or energise brake plume
2 ) induced drag from compromised aerodynamic flow to the rear wing area as the ducting extends from the outboard brake
3 ) structure to the inboard exhaust and diffuser sections
4 ) increased complexity of the system
5 ) increase weight from ducting etc
6 ) inadequate plume velocity
7 ) possible vehicle handling sensitivities due to event timing of braking applications affecting aero balance
8 ) issues over-cooling the brakes due to trying to meet flow requirements
As a summary, there may be some general, small benefits, however I am not sure the weight, complexity, compromise and possible negatives could be effectively overcome or ignored to see the system provide a benefit over other solutions.
Then again I might be totally wrong..
Never approach a Bull from the front, a Horse from the back, or an Idiot from any direction
