"Why are the noses raised than? "
To direct air around the sidepods and over the diffuser
I think, that "shelf" at the front is there due to regulations not because it was invented by designers...The raised nose does not necessarily send more air under the flat bottom - to look at it, there is often a projecting shelf at the front of the floor I can visualise air forming high pressure on the top surface of this. Is'nt the high nose about managing air to the sidepod intakes and then around and over the sidepods (i.e. you get a cleaner flow into the intakes and also back to the ever important rear wing)?
I agree, but if can let more air out than can be brought in than that is a plus to downforce.More air does not mean lower pressure, faster air does (EDIT: which is what Dave said - I was typing this while he posted!). Sending too much air under could easily slow it down surely?
Or, to put it another way, you want more air out than in..........![]()
We obviously don't agree about this one... When high noses were introduced it was only to provide more air under the car (that was before plank was imposed and rear end downforce "killed").kilcoo316 wrote:"Why are the noses raised than? "
High noses laterally splits the airflow cleaner, sure if they wanted to put the airflow under the car, they wouldnt have a splitter, but drop the monocoque to the ground at the front of the current splitter plate.manchild wrote: We obviously don't agree about this one... When high noses were introduced it was only to provide more air under the car (that was before plank was imposed and rear end downforce "killed").
Directing air "around" the sidepods is not what I believe high nose is doing better than low nose. If you want air flowing more sideways than why bring it to the middle of the car and split it there instead of splitting it on the very front end of the car?
Same goes for directing the air "over" diffuser. I don't get it...
