Snap oversteer on a 9hp kart Those things are pretty much flat out everywhere from my experience. Must be some really twisty track you're racing on.Kiril Varbanov wrote:I have raced both 6 and 9HP karts - different tracks have different grip levels, and that's for sure, so you need to adapt.
Generally, I tend to brake very late and spool the throttle at the same time while turning in, so I get out of the corner on proper revs.
In S corners (a la Ascari on Monza) where I'm flat out others aren't so sure. I started doing karts when I was 65kg, now I'm almost 90, and the weight is an advantage. General fitness is also a plus, as on endurance races most give up - the karts that we drive are very nervous and require strong hands for prolonged amount of time.
What I'm not particularly happy about is the snap oversteer induced by low levels of grip on certain track - gives you very little confidence to "push like hell" and generally kills the fun.
This is the layout of our local kart track and I can tell you, 9hp karts do not oversteer or understeer here at all.
