Ferraripilot wrote:From an engine builders perspective (I do quite a bit of Ferrari engine work, racing and stock), I often get rather particular regarding oils especially in a motor I have built where I know the rod and main bearing clearances. Ferrari rod and main journals are rather small and run between .0015-.002 bearing clearance yet these engines obviously rev on the high side, does it matter one way or another what weight an oil is as long as the boundary layer is strong enough to protect at high rpm and high heat? I'm guessing film strength and oil weight are hand in hand?
For instance, I typically like to see an oil with an HTHS of no less than 4, but kinetic viscocity at 100C needs to be lower than 19. These are often 40w and 50w oils and I seem to have to often compromise one thing over another and I'm not sure if I'm wasting my time doing this. Motul 300v is without a doubt the best stuff I've ever used for what it's worth though.
Kind thanks for posting regarding a topic you are obviously massively knowledgable.
These are good questions.
First of all, we need to use the correct terminology. With journal bearings, it's the
hydrodynamic fluid film that supports radial bearing loads. The term "boundary" implies certain conditions exclusive of hydrodynamic operation.
Secondly, while oil viscosity characteristics do have an effect on the fluid film contact conditions, it is only part of the equation. The variable that actually matters most is the local heat transfer occurring within the fluid film contact between the fluid and the bearing/journal surfaces. There is a local rapid temperature rise within the oil film that takes place at the contact zone, referred to as "flash temperature". The flash temp increase results in reduced viscosity within the oil film.
As for small variations in bearing clearances, they have little real effect on load capacity or efficiency. Bearing clearances are mostly based on ensuring there is enough oil mass flow through the bearing gap to ensure adequate cooling of the bearing and journal surfaces. The thickness of a bearing's hydrodynamic oil film is only a few micro-inches. Thus a variation of .0005 inch in installed bearing clearance, which is many times greater than the total operating oil film thickness, is relatively insignificant.
However, what matters far more than assembled bearing clearances are the structural deflections of the main and rod journals during operation. Once you understand that the hydrodynamic fluid film thickness in a journal bearing is only a few micro-inches, you'll appreciate that even tiny torsional/bending deflections produced in a crankshaft can cause excessive edge loading across a bearing journal face.
