must use poppet valves, variable lift and or timing is not permitted, so there's no point in even trying a cam less designStivala wrote:I excuse myself for coming this late on this subject.
In my opinion this expansion cycle design will not be used in a F1 engine.
This is something that is dreamed about by F1 engine designers, this F1engine designer dream falls into the category of the cam less design which although a designer dream was never used in F1.
Agreed,riff_raff wrote:There would be no improvements from using this system in any recip piston engine. The additional mechanical losses from the added bearing surfaces and gear contacts would more than offset any potential gains from improved combustion efficiency. With a high rpm F1 engine, this concept would present especially difficult problems, due to much higher masses that the rod bearing must deal with, the larger size needed for the rod big end, and the large, reversing dynamic forces that the phasing gears must accommodate.
I've seen lots of similar concepts. This is just a new twist on an old idea. But it offers no real improvement.
