I can't find it but I believe it is a rule, it is for safetyagip wrote:Sorry if its a stupid question but, is it a mandatory regulation to turn on the rain lights like that? And why? Safety?
It is for safety.. To warn drivers behind when the lead driver is off throttle.langwadt wrote:I can't find it but I believe it is a rule, it is for safetyagip wrote:Sorry if its a stupid question but, is it a mandatory regulation to turn on the rain lights like that? And why? Safety?
Joe, a few questions about the flashing rain light. I thought the rain light also flashed with during the following situations:joetoml1n wrote: It is for safety.. To warn drivers behind when the lead driver is off throttle.
From Autosport:
"If you are flat out on the straight and you are above a certain threshold - above 95% throttle for more than one second, and you are above 180km/h and you see a 120KW torque reduction - it flashes the rear light for a second to warn the driver behind."
This system only works on the automatic fuel saving modes, and does not cover the situation of drivers suddenly adopting 'lift and coast' tactics.
I understood it as the driver being full throttle (using ERS) until the MGU/ERS enters a harvesting mode which is when the light flashes. 120KW is the maximum output of the MGU-K, so it would imply there can be no MGU-K power delivery when the light is flashing.supertweet wrote:Joe, a few questions about the flashing rain light. I thought the rain light also flashed with during the following situations:joetoml1n wrote: It is for safety.. To warn drivers behind when the lead driver is off throttle.
From Autosport:
*ICE power reduced @ full throttle, -K and -H supplying full power
*-K reducing % of rated 120KW at full throttle in addition to aforementioned transition to harvesting mode.
*Per your 1st sentence, when driver transitions off throttle but w/ no brake application (i.e. near end of straight/lift&coast)
Is this your understanding?
