As you can see in these pictures, there is a oscillating mass force of first order.
Both pictures are "Otto- und Dieselmotoren" ISBN 978-3-8343-3078-9
The oscillating forces can get a very high value compared to the combustion forces.MadMatt wrote:...
We all agree that for example the balancing mass of the crankshaft opposite the piston is there to balance the piston's vertical movement. But that doesn't take in account the combustion stroke, so why do we even bother balancing the crank to the hundred of a gram?
Can't see your pictures but you must have missed something important, for a symmetrical crank the dummy masses aren't needed, thousands of engines per hour are balanced without them. Yes, there are individual forces for each crank pi, but summed over the whole crank, nothing.rscsr wrote:no
Yes I feel like I cannot "click" things together. What bothers me is that they put dummy weights to simulate the piston, conrod and other small bits, but when the engine is running, the combustion will increase the dummy weight you would have to put on the crank in order to simulate this, isn't it?strad wrote:I think your mixing up balance and the forces exerted by combustion.
Balanced is balanced.. Much like your wheels and tires.
I do wish I had my old video of the crank flexing when running.
Amazing how much it flexes and is the reason for past discussions over the advisability of using a cast or forged crank.
There are videos on YouTube about balancing cranks and assemblies but I cannot find one showing how much it flexes between main caps.
the combustion forces are rotational tho surely ? trying to twist the engine, not shake it up and down ?MadMatt wrote:
It is a bit like when you are balancing a wheel and try to accelerate it with your hand while rotating on the machine, the balancing will be out. Or there is definitely something that I don't understand.![]()
I think you are confusing weight forces (which are a function of mass, geometry and rotational speed only) with combustion forces (which are a function largely of cylinder pressure). Engine balancing is only attacking ONE of these effects.MadMatt wrote:Yes I feel like I cannot "click" things together. What bothers me is that they put dummy weights to simulate the piston, conrod and other small bits, but when the engine is running, the combustion will increase the dummy weight you would have to put on the crank in order to simulate this, isn't it?strad wrote:I think your mixing up balance and the forces exerted by combustion.
I'd disagree there. The combustion force (in the conrod) is seen almost entirely by the crank main bearings. Any force "F" applied at a lever arm "L" from a pivot joint is seen by the pivot joint as the sum of the force F and the moment FxL.strad wrote:It also has to do with the fact that the crank pin should be at approximately 90° at the time of combustion so that it pushes the crankpin around what I guess you guys call the pivot point. It's not like it's trying to push the crank out of the bottom of the engine but rather is what makes it spin,
& there is a bit more to it than that..riff_raff wrote:A multi-cylinder recip piston engine crank assy is subject to a combination of forces and moments due to dynamic and combustion effects. The counterweights used on a crankshaft are designed to provide the best compromise of dynamic balance, main bearing loads and torsional vibration characteristics.
