How would a cheap engine compare?
473
Re: How would a cheap engine compare?
Pierce89 wrote:
Shooty81 wrote:There is one issue with any BOP:
when different concepts should perform at the same level, the easiest way is to be the only competitor to us a certain concept. So you can build an inferior car, use a different powerunit, and get yor Performance balanced to match te other concepts.
Probably one o the the reasons why Porsche and Audi both participated at LeMans...
Well, also in the WEC, Aston and the Corvette are the same concept/configuration but Aston gets huge BOP breaks compared to the Corvette. in Lmp1, balance is only diesel vs gas, so the NA Toyota suffers against the turbo Porsche.
LMP1 engines are balanced for fuel type and amount of hybrid energy they use per lap.
So the Audi has a higher fuel flow rate than the Porsche because it is in the 4MJ hybrid category and the Porsche is in the 8MJ hybrid category. Then there is a factor to equalise between petrol and Diesel, which lowers the Diesel fuel flow rate.
473
ian_s wrote:i'd love to see an F1 car built around this years Porsche WEC PU, and the FIA could just turn the fuel flow limit down if they prove too fast.
I doubt that they would be too fast.
Some of the speed for the Porsche is from the use of an 8MJ hybrid system, which provides almost half the power. This system is quite large and heavy compared to the F1 ERS, albeit with a lot more power.
To be raced in F1, assuming the ICE configuration is allowed, the Porsche 919 PU would most likely have to conform to the 2MJ/4MJ/120kW rule. In which case most of the performance would come from the ICE, and the evidence seems to suggest that Mercedes and Ferrari would be significantly ahead on power.
