Best setup chassis guide for real race and racing games
Rustem 1988
Rustem 1988
Re: Best setup chassis guide for real race and racing games
DaveW wrote:
31 Jan 2018, 11:25
Rustem 1988 wrote:
31 Jan 2018, 10:18
I want to know how camber force affects on understeer and torque balance.
I think you have good advice, Rustem. If you don't like it, question your model.
If you require answers for a real race vehicle, you may need to add "installation" stiffness (Sprung mass is seldom a monolith).
Is it "installation" values for camber and cornering stiffness? For example, if lateral force Y=Ca*a+Cɣ*ɣ, then Ca=-10000 and Cɣ=100 or other values.
Rustem 1988
Rustem 1988
Camber force=Cɣ*ɣ but I think that camber force force must depend on the speed of the car.
In the steady state of corner M*v*r=Ca*a+Cɣ*ɣ. I want to know forces and moment of car for different speeds.
Rustem 1988
Rustem 1988
Why, when the different stiffness of the springs, tires and shock absorbers, the trajectory of the car can be different?
Rustem 1988
Rustem 1988
This is probably due to the fact that when the load changes the cornering stiffness of the tires and the slip angle changed, too.
Rustem 1988
Rustem 1988
If you were asked to evaluate the efficiency of the setting what data would you be interested in first?
Rustem 1988
Rustem 1988
Which simulator is the most convenient for studying the settings of the car?
Greg Locock
Greg Locock
238
Have you read this? http://phors.locost7.info/contents.htm
Learning about vehicle dynamics from a racing game merely means that you are debugging whatever errors the game designer has made, deliberately (for speed or excitement) or accidentally.
Rustem 1988
Rustem 1988
Greg Locock wrote:
10 Mar 2018, 21:47
Yes.
