Zandvoort
RZS10
359
Re: Zandvoort
In DTM most overtakes happened because drivers chose very different lines through many of the corners but that was years ago, haven't watched DTM recently so i don't know if that has changed.
bauc
Re: Zandvoort
Tim.Wright wrote:
23 Nov 2019, 09:11
30% is massive. I hope someone told Pirelli about this a long time ago.
Great point!
3jawchuck
3jawchuck
37
Re: Zandvoort
Tim.Wright wrote:
23 Nov 2019, 09:11
2005 is calling.
Godius
186
Re: Zandvoort
I think it will be comparable to turn 13 in Shanghai, entry speed is relatively low.
Sieper
73
Re: Zandvoort
I think this solution might, just, give us an overtake opinion at the end of the straight. Will be much like Suzuka (one real overtake spot) If succesfull.
FW17
185
Re: Zandvoort
Will the circuit line that banked corner with a run off or put a wall like in a speedway?
Re: Zandvoort
The work in the dunes has started.
Photos from Instagram of Ferry de Kok, photographer.
waynes
waynes
Re: Zandvoort
are they putting in a load of concrete run off?
Juzh
161
Re: Zandvoort
From this image we can see main straight is apparently around 680m.
With predicted 30+ degrees banking I'd say cars will be flat pretty soon after the second to last corner, from around this point, or maybe just after:
Based on google maps measurements this will make for a total of around 1 kilometer of flat out section. Because of high banking the car following should have no problem staying full throttle.
For comparison, Hungaroring main straight is ~750m on google maps.
Sieper
73
Re: Zandvoort
And after that we have the Tarzan corner were daring drivers can grab on to a liana (with right hand) to carry a higher speed through that corner.
Kidding aside, the 1 km should hopefully be enough to have a viable passing opportunity. I would think so.
mertol
Re: Zandvoort
Maybe they will leave the flat part and make the banking on the outside of it.
RZS10
359
Re: Zandvoort
That's what i wrote in a post which i apparently forgot to send (only the preview, unless it got deleted without reason ... lol) ... Is there a properly banked corner on any track which doesn't have walls on the outside? Maybe they'll just extend the track in order to add the banking.
One more pic from twitter
waynes wrote:
26 Nov 2019, 14:37
No. https://f1i.com/news/348536-zandvoort-t ... eturn.html
One aspect Zandvoort will retain is the presence of its gravel tracks which have been preferred to the installation of forgiving asphalt run-off areas.
"We are keeping the gravel," Zaffelli told RaceFans. "This was one of the requests from all the parties.
"FOM requested it because of the heritage of the track. The track [owners] asked for it. And as you know we are more than happy to have gravel instead of asphalt if we think that it is not necessary."
Jolle
Jolle
133
Re: Zandvoort
so... lot's of safety cars :D
strad
117
Re: Zandvoort
You guys keep mixing up % and degrees... It will only be 18°
Sir Stirling Moss
Re: Zandvoort
"We are going to turn the Arie Luyendyk bend into a bend with a gradient of 32 percent,
so that the difference in height between the top and bottom of the bend becomes more than four and a half meters."
That's what the circuit director Van Overdijk tells us.
