hsg wrote: ↑26 Apr 2025, 21:11
Silent Storm wrote: ↑26 Apr 2025, 19:56
If your main goal is to avoid front tyre wake entering under the floor, fences placed inside (inboard) of the floor edge are the better choice. Placing fences slightly inboard lets you catch and manage the dirty tyre wake before it spills into the low pressure floor area.
Main goal is to get maximum downforce with that floor, everything should be tailored to that goal.
One solution is use all floor area, second is use less floor area but with more quality airflow, which solution is better I dont know. If I have photos of of race cars floors I will come to conclusion which solution is better.
Right now you're trapped in a false binary...
It’s not “use all the floor and accept dirty flow” or “give up floor area to get clean flow.” Both solutions can work depending on execution...
The best solution is to use the maximum floor area available, while actively managing and cleaning the flow quality using fences, strakes, and tyre wake management.
Shrinking the floor area throws away huge potential downforce. The goal is to protect the floor, not delete it.
Every real aero car (LMP1, prototypes, even some touring cars) maximizes floor area and then uses intelligent flow control (deflectors, fences, slots) to maintain good pressure recovery.
Real world aero is always about finding ways to use what you have, not cutting parts away because flow isn’t perfect.
There’s no ready made answer or magic photo that tells you what to do. It’s always about applying principles to your specific situation and constraints.
