I don't believe they are getting any fuel savings from it .. it probably uses more fuel given that speeds are higher so they end up reaching the same drag levels.sknguy wrote:Is there any info about how much of a fuel saving the stall duct provides the teams that use them?
A team building cars that good, doesn't luck into performance. The RB4 was a good car, the team was just immature.SoliRossi wrote:Mike, I also think redbulls previous wet weather pace has been a bit of an anomaly. It seems their previous wet weather pace came from massive downforce generated by a good car but more so by the profile of last years wet weather tyres. Ant talked about it last year, the RB5 and even RB4 seemed to make a huge leap in performace, and it was caused by the car 'clicking' withthe profile or dimensions of the wet tyres working with the rest of the car.
He kind of alluded that it was almost lucked into and not really understood by the team.
So perhaps this year the new dimension in wet weather rubber just does not click at well with the car and they in turn are more at a normal pace.
I suppose what im saying is the last few year performance of the redbull in the wet was not acheived by specific design and understanding but more so good fortune.
There is always a bit of luck envolved, Red Bull would not have designed the car to work well in the wet it just worked out that way. They had a lot of down force which helped, but they also worked the tyres in such a way that happened to work well with the wets.Pierce89 wrote:A team building cars that good, doesn't luck into performance. The RB4 was a good car, the team was just immature.
Granted, but cars with less BHP also benefit, as has been evidenced very many times in the past. Kovi in the LOtus, would be closer to the front in bad weather. Part driver, part less power!autogyro wrote:IMO wet weather results are more a result of the drivers ability rather then the car. All F1 cars perform badly in the wet.
Maybe thats why Kovi is in a Lotus! He cant drive in the wet...........?gilgen wrote:Granted, but cars with less BHP also benefit, as has been evidenced very many times in the past. Kovi in the LOtus, would be closer to the front in bad weather. Part driver, part less power!autogyro wrote:IMO wet weather results are more a result of the drivers ability rather then the car. All F1 cars perform badly in the wet.
