A lot of us on here have first hand motorsport experience... and I simply don't want people going away with the wrong info:
Slightly rich is better for full power.
Strad wrote:The engine is nothing more than an air pump
...I'm sorry, but you've taken that quote to its absolute extreme and come up with the wrong answer... you can
think of an engine as an air pump when determining
certain characteristics of the engine... but it ISN'T AIR AIR PUMP... An air pump takes power in to move air. An engine puts out power by BURNING fuel and air (actually, just the oxygen)...
Its easier to put more fuel into the mix (using carbs or injection), but it gets increasingly hard to get as much air as you can into the engine.
To get as much power as possible you need to burn as much of the oxygen as possible to release the energy in the fuel. In order to ensure that you burn all of the oxygen possible scientifically you need only a stoichiometric mix.. in reality all of the oxygen molecules won't "find" a fuel molecule to react with so you need to go slightly rich to make sure they do...
As a reference, Below is a fuel ratio meter made by Alpha for the motorsports industry. It measures free oxygen levels in the exhaust gas to determine what air:fuel ratio you are running at. Best power is achieved when the green lights are illuminated, i.e. a lambda reading of approx 0.9.
Spotted you're mistake I think:-
Strad wrote:No..somewhere in the 13-14:1 range..whether you use injection or carb.
FYI... an Air:fuel ratio of 13-14:1 is
RICH!!!! it tells you that you have less air than in a stoichiometric mix.... (i.e. relatively more fuel).
