Technical or not there are rules on any sport, and today Redbull has braking them not following advice, deciding by themselves that the FIA sensor was faulty and use their own.jz11 wrote:you can't compare technical sport to olympic walking
the thing is - if they would have reduced the fuel flow, they would lose the place for sure, and if they would have found out afterwards that the sensor was indeed faulty - no one will ever give them higher position, you cannot expect FIA to say - of yes, our bad, lets move your driver 3 positions up!
there was no real win situation for RB here, its lose/lose or lose and maybe argue your way out of it
IMHO - if FIA really wanted to do this right - certify injectors, certify fuel delivery system and check injection maps - that is it, and use the flow sensor just for reference, if someone is a suspect - investigate, not penalize someone based on some not-too-reliable sensor data
and why did they not go to the B. option of the rule book? didn't look at the maps?
As the FIA states on the decision statement
b. “If at any time WE consider that the sensor has an issue which has not been detected by the system WE will communicate this to the team concerned and switch to a backup system”
I assume the FIA didn't call on the middle of the race just blind, there were probably alarming details to do that call.
They ignore the call and the chance to rectify, consequently they got disqualify because they didn't prove wrong the FIA after the race.
The took the risk they lost any possibility of points. They could have finish 5th or 6th if following the advice far more better than nothing.
If other teams would have problems with the sensors I will feel sorry for them. But just one team who for the last 4 years have being playing well with rules, loopholes and politics, had this problem. When you play this game some times you win and sometimes you lose. And in this occasion as I said, they f+++ themselves.
