2022 Tyres Thread
JordanMugen
82
Re: 18-inch wheels to be introduced in 2021.
henry wrote:
24 Sep 2019, 20:13
IMHO it’s the rippling sidewalls that allow them to ride the kerbs. The tyres conform to the kerbs keeping maximum contact patch.
Yet a V8 Supercar rides kerbs just fine with a 18" tyre with much less sidewall than that proposed for F1. I think having a large amount of suspension travel available and the use of a spool (non-)differential has a lot more to do with good kerb jumping ability...
Just_a_fan wrote:
24 Sep 2019, 19:12
If taking the kerb is quicker, they'll take it - cool or otherwise.
Having a short sidewall tyre does not preclude a car from using a kerb! It is, rather, a matter of the available suspension travel... Indycar rides the kerbs just fine as it uses reasonable sized coil springs and shocks... The F1 designers have become addicted to their 13" tyres and fit their vehicles with "mini" sized springs and shock absorbers... They may need to reconsider that. :wink:
Dallara DW12
vs
Toro Rosso STR13
Just_a_fan wrote:
24 Sep 2019, 19:10
Will low profile tyres require the suspension to be stronger?
Not stronger, but it will need to have more travel. As you can see above the F1 suspension components are undersized compared to the normal components used in other open wheel series.
Compare the rear suspension for instance...
The robust rear damper unit used in the Indycar:
The F1 rear damper is so tiny, it is not even visible in the drawing, hidden somewhere down by the exhaust manifold. :wtf: :?:
FW17
168
JordanMugen wrote:
25 Sep 2019, 15:51
henry wrote:
24 Sep 2019, 20:13
https://nnimgt-a.akamaihd.net/transform ... 8_fmax.jpg
Just_a_fan wrote:
24 Sep 2019, 19:12
https://cdn-1.motorsport.com/static/img ... -matta.jpg
https://www.racecar-engineering.com/wp- ... pir12a.jpg
Dallara DW12
vs
https://pbs.twimg.com/media/D2WN1oHWkAATgSs.jpg:large
Toro Rosso STR13
Just_a_fan wrote:
24 Sep 2019, 19:10
https://s3-eu-west-1.amazonaws.com/cras ... 148982.jpg
http://www.thepaddockmagazine.com/wp-co ... 50x670.jpg
That is not the case, that other open wheel series have larger springs
F1 had larger springs at the beginning of the era after active suspension. But with years of development they have managed to reduce the size of the components while doing the same (and a lot more) functions
henry
324
I’ll quote James Key:
Will there be a bit of grip loss for those different 18-inch rim tyres? Maybe, they’ll be different animals.
https://www.racefans.net/2019/09/25/rac ... p-25-09-2/
So he’s not expecting large gains from being able to design suspension with more travel. Quite possibly the reverse. He may be referring to the narrower fronts but in that case I think he would have said so directly.
izzy
izzy
henry wrote:
25 Sep 2019, 17:22
i noticed this. I don't get the physics of why there won't be more grip, for a given tread width as you say, with basically more control over the contact patch with having a shorter sidewall. They should be able to load the tread more evenly, especially at the edges and especially the inside edge.
FW17
168
:lol: :lol: :lol:
izzy wrote:
25 Sep 2019, 18:00
henry wrote:
25 Sep 2019, 17:22
:lol:
Maybe because the driver can call for max torque and the tread does not give up and slip, but rather the side walls flex
JordanMugen wrote:
25 Sep 2019, 15:45
Just_a_fan wrote:
23 Sep 2019, 17:48
The stretched tyre is only a fashion amongst a small minority.
A small minority of car manufacturers and their original fitment tyres? :wink:
https://anythingauto.co.uk/wp-content/u ... 60x640.jpg
https://images.autotrader.com/scaler/62 ... 250627.jpg
They aren't "stretched tyres", they're low profile with a large wheel protector rim incorporated above and outside of the bead. The tyre protects the expensive alloy wherl this way. Quite common on all types of tyre.
strad
117
world of difference between "wrinkle wall" slicks and any other racing tire.
Sir Stirling Moss
izzy
izzy
FW17 wrote:
25 Sep 2019, 19:12
:lol: :lol: :lol: :lol:
oh cool. what happens when the sidewall can't flex any more? or are they those everflexing kind?
henry
324
izzy wrote:
25 Sep 2019, 18:00
henry wrote:
25 Sep 2019, 17:22
My understanding is that current F1 suspension does not follow a simple spring and damper model. It is much more sophisticated and in particular includes another control element, the inerter. This means that even though the tyre has a low spring rate and light damping it is maintained in contact with the road, and being in contact it’s localised flexibility allows it to conform to the road surface, no matter how rough, with a large contact patch. The 18” solution may be able to maintain similar contact patches but it’s localised stiffness will prevent it conforming as much and so will have a smaller contact patch.
As for the physics, here’s a basic description of inerter function, https://www.highpowermedia.com/F1-Monit ... he-inerter
And here is Prof Smith’s original paper about it. https://pdfs.semanticscholar.org/f791/a ... 1569434358
izzy
izzy
henry wrote:
25 Sep 2019, 23:27
awesome thanks :)
strad
117
Lot of reading there but from this part :
One area where inerters are of particular use is on vehicles with large tyre sidewalls, such as those in Formula One. A large sidewall is more prone to uncontrolled deflection at high suspension frequencies, which an inerter can be highly effective at combating, the result being a more consistent tyre contact patch and thus greater mechanical grip.
I deduce that an inerter will be of far less importance if used at all.
Sir Stirling Moss
henry
324
strad wrote:
26 Sep 2019, 01:43
That may be the case, although I think they have been used on LMP1.
FW17
168
Mclaren testing 2021 rim style?
cplchanb
cplchanb
FW17 wrote:
26 Sep 2019, 13:46
https://d.radikal.ru/d27/1909/9a/7e787722bc67.jpg
Prob just transport or scrap rims for practice
strad
117
that's not an 18 inch rim.
Sir Stirling Moss
