2022 Alpine F1 Team
Re: 2022 Alpine F1 Team
NL_Fer wrote:
04 Feb 2022, 12:05
Any idea how the relation is between the chassis builders in the UK and the engine plant in France? I wouldn’t be surprised if they have some of the problems like Redbull had with them.
Makes no sense. The RB-Viry story is a completely different story.
The relation between Enstone and Viry is certainly excellent. Their RS.19 chassis/PU integration proves that there is a big osmosis between Viry and Enstone. The fact their engine intake plenum and intercoolers connect directly to the back and sides of the monocoque respectively, to air ducts that are integrated to the tub, is a never-seen-before solution in F1. And you need an unprecedented level of osmosis between the engine and chassis departments to do such thing, because it's a part of the engine that almost merges with a part of the chassis.
And the team said since 2019 that it intends to push this approach further and generalize it to the whole PU.
NL_Fer
NL_Fer
82
Blackout wrote:
04 Feb 2022, 12:27
NL_Fer wrote:
04 Feb 2022, 12:05
You are right. I forgot they have a 25 year collaboration on/off as a factory team or custormer. Only 2015 Lotus Mercedes was a single year interruption.
Kukrika
Kukrika
When I look at the new Haas car with too wide sidepods can we expect the new Alpine car to have a “bulky” air box again?
JPower
JPower
43
Kukrika wrote:
04 Feb 2022, 18:50
How do you know they are too wide?
Kukrika
Kukrika
It looks like they are. Why do you think that they aren't too wide?
JPower
JPower
43
Kukrika wrote:
04 Feb 2022, 19:37
Eyeball aerodynamics huh? Interesting.
Kukrika wrote:
04 Feb 2022, 18:50
The A521 airbox is a very special case and you shouldnt use it as a reference.
It was very wide because it was a big compromise: the cooling system it contained wasnt designed for that frozen chassis, and that chassis wasnt designed for the 2021 cooling system.
The 2021 cooling system change was unscheduled, like the 2021 freeze and aero changes.
So that cooling system integration was not optimized. viewtopic.php?p=1023376#p1023376
If Alpine had unlimited time and resources and tokens in 2021, they would have redesigned their tub around the 2021 cooling system and had a much thinner roll hoop, like the RS.20 or thinner, or the Renault-powered Mclarens.
But they froze their own tub design in 2019... then the unexpected freeze and 2022 delay came in 2021...
Besides, the A552 cooling system is said to be 1-very different than the last 3 seasons and 2-smaller too.
And unlike the A521, the 22 car tub will be tailored around the cooling system.
So if they continue with a classic centerline layout in 2022, they will certainly switch around the top and bottom roll hoop intakes, to follow the other teams, and have a thinner rollhoop...
Being that Fry last ran the pull rod front suspension in 2013ish with Ferrari, wonder if they'll run it this year at Alpine?
AeroDynamic
349
BWT Alpine it is!
Starscreamer
AeroDynamic wrote:
11 Feb 2022, 12:22
BWT Alpine it is!
Pink is back =D>
Combine of pink and blue can make a nice fresh livery :-D
#33 2 THE M4X V3RSTAPP3N
Jambier
Not sure I will like it :?
But good news to have a big sponsor like that! Hope they can really be at the budget cap, and spend the most money possible on this crucial year.
The pink with blue let's see, but 2021 livery was so beautiful.
On the clothing side same thing, they are going to Kappa, but Le Coq Sportif wear was very nice
Be nice if it is 100M a year but I doubt it. Maybe 25m. Good too.
I like the Alpine livery but Money makes the wheels go round. For 25m.. I love pink!
Sieper
73
Jambier wrote:
11 Feb 2022, 13:59
Pink with the french tricolore can be very beautiful. We'll jus have to wait and see. Last years alpine car had a very nice livery too imho.
I guess Otmar is only a motion away.
wogx
