Mercedes W15
Venturiation
Venturiation
103
Re: Mercedes W15
Better front
Re: Mercedes W15
The sidepod inlet almost looks like the W13 inlet turned on it's side:
#ReleasetheADUO
HungarianRacer
HungarianRacer
37
Re: Mercedes W15
Venturiation wrote:
15 Feb 2024, 00:00
Better front
Some water spray rolling off the 4th front wing flap around the pseudo-Y250 generating area:
EDIT: GIF framerate increased.
mantikos
mantikos
Re: Mercedes W15
HungarianRacer wrote:
15 Feb 2024, 00:36
Venturiation wrote:
15 Feb 2024, 00:00
Better front
https://i.imgur.com/PXNzcBx.gif
I believe those are reflections of the markings from the track surface, probably too slow for something to be that apparent
vorticism
vorticism
449
Re: Mercedes W15
I dub it the string wing.
shady
shady
Re: Mercedes W15
Good luck, HidePods never really took off..
DiogoBrand
74
Re: Mercedes W15
15 Feb 2024, 00:15
https://i.ytimg.com/vi/pP6T1comENg/maxresdefault.jpg
Perhaps they just have one stencil to draw the inlet so they had to improvise.
patrik
patrik
Re: Mercedes W15
15 Feb 2024, 00:36
https://i.imgur.com/tDjTpaX.gif
Those are reflections from the track paint
auem123
auem123
Re: Mercedes W15
15 Feb 2024, 00:36
Venturiation wrote:
15 Feb 2024, 00:00
Better front
Hello, is it because of the angle of the shot( in the gif) or the second element of the front wing is quite narrow? It was not like that in the render....
atanatizante
133
Re: Mercedes W15
Luscion wrote:
14 Feb 2024, 19:30
https://pbs.twimg.com/media/GGUIDZxW8AA ... name=small
Very bulggy driver upper cockpit area resemble Alpine from a couples of years ago... not so good for the CoG... did they placed stuff above the car just to have a big undercut?
Jesus
Matt2725
Matt2725
Re: Mercedes W15
atanatizante wrote:
15 Feb 2024, 09:35
Luscion wrote:
14 Feb 2024, 19:30
I don't think it's really any bulkier than last year's car. Less so perhaps in some respects.
Also worth nothing the angle upon which this photo was taken, is from above likely on a gantry or bridge. That "bulk" is sloping down towards the rear of the ca rather than all being sat up high.
chrisc90
Re: Mercedes W15
Kyle’s Analysis.
f1316
88
Re: Mercedes W15
One thought occurred to me: with this front wing, you are sacrificing some actual surface area (and hence downforce) for this vortex generation. I know that conventional wisdom is that this is a fine trade off but I wonder if, with this generation of cars and the large diffuser/rearwards downforce centre, other teams haven’t followed this route purely for a question of balance?
Part of the reason this occurred to me is because it seems so simple that I’m surprised no one thought of it before (including Mercedes given, as shown here, they essentially exploited a similar trick in the past anyway).
Owen.C93
Owen.C93
189
Re: Mercedes W15
f1316 wrote:
15 Feb 2024, 16:44
They aren't really front end downforce limited in the current regs. There's plenty of scope to increase front wing angle of attack for more front load. The current wings are optimised for flow structure and efficiency.
So worst case they become a bit less efficient on the front end. But I don't think it's going to make an understeery car with no scope to resolve it.
scuderiabrandon
111
Re: Mercedes W15
15 Feb 2024, 00:36
Venturiation wrote:
15 Feb 2024, 00:00
Better front
that's reflections from the armco barrier.
The supposed vortex you are pointing out here way too far inset from the shedding edge on the front wing and I doubt you'd see it roll over at 30mph.
