Not really, only if they were running different versions of software. That they were differently impacted does not mean the software was different.Matt2725 wrote: ↑23 Jul 2026, 13:45Okay so can we can it with the idea that George was the problem?Lasssept wrote: ↑23 Jul 2026, 13:43The Race- Mercedes makes software fix after Spa problems
The Mercedes Formula 1 team has made deployment software modifications ahead of this weekend’s Hungarian Grand Prix to help address a problem it found deep in the code on George Russell’s car in Belgium.
The problem that Russell faced in qualifying was related to an element deep in the code on his power unit that meant his deployment was being front-loaded around the lap.
This meant that, as part of the adjustments that are made by the algorithms to manage energy around the lap, it was more biased to using extra energy on the run to Les Combes.
This, allied to some differences in how he and Antonelli then impacted harvesting and battery usage around the middle sector, meant he was short of power for the run to the final chicane.
Having uncovered the issue in the code that got exposed in Belgium, Mercedes has put countermeasures in place from this weekend to try to make sure that there are no repeat problems.
Deployment should also not be too big a factor in Hungary as it is a much more energy-rich circuit layout.
