Mclaren Mercedes MP4-25
Pandamasque
Re: Vodafone Mclaren Mercedes MP4/25
Is it just me or they effectively reverted to the late MP4-24 rear end design?
Confused_Andy
Confused_Andy
On page 28:
Confused_Andy wrote:Didn't they start 2009 with a similar exhaust exit and then ditched it for amore open exit for greater cooling, I can't imagine the end of those sidepods will stay like that for very long.
Just to quote myself so I can bask in the glory.
Pandamasque
The big question is would they make that change so without you suggesting that? :lol:
well, those new cooling holes do actually make the downsloping sidepods useless as it has to go up again. Not actually the best place to place cooling holes if you ask me
jason.parker.86
jason.parker.86
Lewis in the car, let the good times roll. Button is a good drive, but not a scrach on Hamilton! I think the car will start "ok", and they will do there normal trick of finding 0.5secs just as they get to Europe, by which time they will spend the rets of the season catching up, and then half way thru the FIA will find a reason to ban them...
ISLAMATRON
Button makes it sound like it is an upgrade rather than a spec solution for the high temps of Bahrain... I wonder if we will continue to see this exhaust setup past the early hot races and in China or Spain. I certainly liked the launch version better... but if it dont work than you gotta fix it.
wesley123 wrote:well, those new cooling holes do actually make the downsloping sidepods useless as it has to go up again. Not actually the best place to place cooling holes if you ask me
I´m still a bit confused about the sidepod shapes evloving recently,and do not really understand why they do slope down as they do.this surely must lead to generating lift in that area and it must be a huge gain in redirecting flow towrds difusser exit and lower beam wing to compensate.
Taken the other way round and doing it a bit more like lotus with a flattish upper surface of the sidepod and a deep undercut to open a ways for the air to access the lower wingprofile could be a more df oriented sidepodshape at the expense of increased licked outer suface area of course...adding drag.
Spencifer_Murphy
Just a thought, check out how the exhaust housing/cooling holes slope upwards. Could they effectively work a little bit like the old sweeps on pre-2009 cars? (dunno if I've made myself clear about what I mean lol!)
Silence is golden when you don't know a good answer.
Spencifer_Murphy wrote:Just a thought, check out how the exhaust housing/cooling holes slope upwards. Could they effectively work a little bit like the old sweeps on pre-2009 cars? (dunno if I've made myself clear about what I mean lol!)
The pre-2009 sweep-ups were more to do with directing air over/around the rear tyres. The exhaust shroud design on the -25 is just about getting air out of the rear of the car in an efficient manner.
jason.parker.86
jason.parker.86
1. Hamilton McLaren 1:20.472 134
Says alot
zgred
jason.parker.86
jason.parker.86
Hammy sporting some new gloves?
Crafty
Crafty
Not sure about new gloves but we haven't seen the gills in those vents before I don't think ?
Also, looking past Lewis, there isn't a huge amount of space there - this thing of the snorkel having tubing up to the airbox just doesn't fly imho.
The long run today was certainly impressive.
bhall
bhall
244
balalev wrote:new bodywork
Could the shape of the new exhaust outlets in the bodywork act like the flipups of former years?
autogyro
autogyro
Is there now a large triangular outlet blowing air from the fin onto the rear wing?
