McLaren MCL36
f1rules
f1rules
636
Re: McLaren MCL36
if you follow the tunnel as reference, before the sidepod was as wide, now...
morefirejules08
morefirejules08
Re: McLaren MCL36
Marc.W wrote:
20 May 2022, 12:55
I'm not seeing anywhere in that document that they have new side pods
Point 5?
_cerber1
302
Re: McLaren MCL36
Emag wrote:
20 May 2022, 12:56
New parts are on Lando's car for fp1. I think it's the old spec on Daniel's car for reference.
New rear wing for Dan?
AeroDynamic
349
Re: McLaren MCL36
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL36
The outer floor strake with the DeWalt logo on is definitely detailed different. So hoping this new floor will give them the uptick in load generated they’ve so been craving
f1rules
f1rules
636
Re: McLaren MCL36
sidepod is updated im pretty shure
Emag wrote:
20 May 2022, 12:56
paulo_f1
paulo_f1
Re: McLaren MCL36
100% a new sidepod, there is a bulge at the top leading edge that wasn't there, the way it tapers in around the sidepod air entry is also now different.
The FIA changes doc list a sidepod update at point No.5 too!!!
Marc.W
26
Re: McLaren MCL36
morefirejules08 wrote:
20 May 2022, 12:57
Marc.W wrote:
20 May 2022, 12:55
Point 5?
Ah yes, no idea where I was looking 😅
bauc
Re: McLaren MCL36
Marc.W wrote:
20 May 2022, 12:55
N.5 on the list - revised sidepods and shape
RZS10
359
Re: McLaren MCL36
Mirrored and (very slightly) distorted to match better.
The shadow might be misleading but it might be a bit tighter in the coke bottle area?
The bulge over the V of Velo was already mentioned.
Flat main plane RW.
The adjustor on the FW moved so the uppermost element is new (at least).
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL36
Yeah the bulge will be the SIPS protrusion. Main reason why Merc could go with the ZeroPods was the rads change which then also required lowering the SIPS. Not an easy change to make. Seems Macca have gone as tight as possible with a conventional layout
Xero
Re: McLaren MCL36
RZS10 wrote:
20 May 2022, 13:06
https://i.imgur.com/IiE21zd.jpg
Flat main plane RW.
Daniel's car definitely has the complete old spec, as they said it would, they're identical. Even has the cockpit strake they said was removed. Let's wait and see what Lando's car looks like, don't think we've seen anything yet.
RZS10
359
Re: McLaren MCL36
So it was misleading shadows :wink:
The FW and RW are def. different specs though between the two pictures.
Re: McLaren MCL36
The side pods are bulkier on TV. More closer to the Alfa Romeo.
Emag
Emag
137
Re: McLaren MCL36
PlatinumZealot wrote:
20 May 2022, 14:35
No undercut though. Looks like a tighter version of Haas' sidepods.
Can anyone with F1TV get a snap?
Developer of F1InsightsHub
