Morteza wrote:I have had enough of reliability problems for car number 7 while car number 8 has had none!
I have no idea what to expect for Valencia, but I know there isn't anything good (hope I'm wrong). Is W03 a very fragile car that makes it hard for the team to provide two reliable ones for a race weekend? What's the reason?
the law of averages would tell you the distribution of dnfs is quite unlikely as we see it here.
But on second thought we don´t really know what happened to the fuel system in Monaco -it may well have been triggered by the impact at the start for example and who knows just what triggered Schumis bad stop.
Was he parking the car exactly were he should ? Or was the issue purely a technical issue with the gun and it was simply coincidence that it was schumacher and not rosberg who fell over it.
More so The DRS was not the first time giving trouble on schumachers car ..was ärosberg equally affected but just at other less punishing times?
And with the gearbox both clearly had issues with the oldand new box already.
Inmy book the wheel fixation issue is something not really under control since ages and as you increase the number of stops + try to minimise the pit stop elapsed time you will soon find yourself at the ragged edge with a wheelgun in your hand and the car is flying into its allocated slot.
No question you can practise and optimise the choreography but you cannot elimnate the risks .thze car can stop short or overshoot can get in sideways or half a meter to the left or right .There is just too much that can go wrong in the process -you got NO control over bolt pretension -so you never know if the wheel is fitted proberly when raising the hand.
You have no control over the removal of the nut as well .The airgun will apply its realease torque and hammer away but what do you know about reléase force ? the mechanic may have that mushy feel in his hand and senses there is something different but else?
I feel the whole wheel fixation is a huge risk and not on a level required for the time you have at your dísposal to change the wheels .
To me the wheel gun should only pretension the hub and throw off the wheel .The mechanic should replace the wheel the pretension mechanism should grab the wheel securely .End of stop.It may be a requirement of the regs to fix the wheel with a bolt though -so maybe the last action of the wheelchange may need to be tensioning the fixation bolt in the lock position.
