Red Bull RB6
timbo
timbo
113
Re: Red Bull RB6
esbjornzon wrote:the red bull rb2 had radiator fans
Proof?
I've seen fans on Renault car, but that was only because it did shows with engine revving.
mep
29
Re: Red Bull RB6
Aah yea I missed that water doesn't expand that much as air does.
So why the inlet has much bigger diameter then?
esbjornzon
esbjornzon
Re: Red Bull RB6
Proof?
kind of new at forums so I don't really know how to post pics etc. but if you google red bull rb2 radiators, there's a pic on the second page. But it could also be because of a similar showing
myurr
myurr
Re: Red Bull RB6
I've seen fans on a couple of the F1 cars when they were at Goodwood. Presumably as they were not running anywhere near the speed they'd need for passive cooling to be effective.
mx_tifoso
mx_tifoso
Re: Red Bull RB6
Seriously? Cooling fans are illegal on all areas of the car. Only during promotional events are they allowed since they are not FIA sanctioned competitions and require slow speeds and full stops.
timbo
timbo
113
Re: Red Bull RB6
esbjornzon wrote:
Proof?
Use img button, it adds tags automatically and you only need to post URL.
I did a search and found this one you probably meant,
It is probably from some promotional event.
No fans are allowed on F1 cars...
Goran2812
Goran2812
27
Re: Red Bull RB6
mx_tifosi wrote:Seriously? Cooling fans are illegal on all areas of the car. Only during promotional events are they allowed since they are not FIA sanctioned competitions and require slow speeds and full stops.
thank you! that's the clear answer I was looking for... :)
fans would make things easier for the teams wouldn't they... heh...
Visit my photo page! -> http://www.gorankphoto.com/formula1
Confused_Andy
Confused_Andy
Re: Red Bull RB6
timbo wrote: Use img button, it adds tags automatically and you only need to post URL.
Yeah thats the Redbull promotion car, not sure what it is a RB5 (but not quite) with a Cossie V10 hence the insanely tall exhausts.
Re: Red Bull RB6
mep wrote:Aah yea I missed that water doesn't expand that much as air does.
If there might be a reason for different diameter it could be temperature. The hot pipe might be smaller so that it can take more stress. my guess.
auto saibot
Re: Red Bull RB6
it is red bull RB01 during mumbai roadshow last year
mep
29
Re: Red Bull RB6
It is no RB x. They use parts from every car trying to have it a bit up to date.
Somewhere in the net is written to which car it comes closest. I think it was RB4.
In the end it has nothing to do with RB6 and so does if fans are allowed or not(They are not). I hope we can end this now or move into separate threat.
Lets focus on the RB6 radiator again.
There are still some questions unanswered.
1. Confirm that big tube is for hot water therefore water inlet.
2. Why are the hot water tubes bigger?
3. Why are they running a split (top, bottom) radiator?
4. How does the water flow trough radiator? I made a assumption on one of my posts that the water goes from the outside of the car to the inside and on the front of the radiator back.
Seems like nobody noticed my comment or I just failed to explain properly. I guess I have to make a drawing to explain better.
Re: Red Bull RB6
Strikingly ,Mr.Newey is a Historic car afficionado...
and Jaguar V12 engines use some intriguing weird double pass radiator layout that reminds me of this one...
The radiator for sure is NOT single pass ,as water in and outlets are on the same side of the core .
So in effect to me this is a front rear divided radiator core as a starter.
But now things get interesting...
No ways the volume of water entering and leaving the radiator is not the same ,as it can´´t produce water ...so just why would he have different water pipe diameters? .
747heavy
Re: Red Bull RB6
just to be a smartarse :D
the mass of the water entering and exiting is the same
the volume is different as the density will change with temp
but I don´t think that this is the point here, in regards to the tube size
- Colin Chapman
Michiba
Michiba
Re: Red Bull RB6
the volume of water doesn't vary significantly as a liquid in response to changes in temp
Re: Red Bull RB6
747heavy wrote:just to be a smartarse :D
I don´´t mind posting the link to the relevant graph again:
http://de.academic.ru/pictures/dewiki/8 ... omalie.png
I´d say 4% in volume change between 0 and 100°C is not justifying an increase in tube size ,especially as we won´t ever see a delta t even close to that value in water temps across the core of the rad... :mrgreen: :mrgreen:
Hopefully the water is not full of air bubbles coming from the engine (if this was the water in tubes)...and they use the big tube as a swirl pot..(just joking there boys).
for me the thing looks like :they had only one big tube to start with but found out they had some issue and solved this by adding the lower pipe ...and just kept the original pipe as it was.
