Is the Aerodynamic dependence in Formula One too high?
Re: Is the Aerodynamic dependence in Formula One too high?
bhallg2k wrote:I still don't see a logical basis for such a rule. I think it's because one doesn't exist.
This is just about tailoring F1 to suit one person's megalomaniacal desires.
You're not the only person thinking that...
Tyler
Tyler
Montezemolo didn't seem to have a problem when the Ferrari's of the early 2000's were dominating in part because of their aerodynamic superiority.
I think he's just jealous that Red Bull is winning and Ferrari isn't.
If it was the other way round , I'm certain he wouldn't be complaining.
Personally I'd like to see the wings made slightly smaller with the front wing being less wide making the cars a bit more difficult to drive.
Not too much though, I still want the cars to go fast through corners but wouldn't mind if they did so slightly slower.
I'd like to have engines producing more hp so that the correct combination of slightly smaller wings and bigger engines keeps the lap times more or less the same, while placing more demand on the driver.
WhiteBlue
92
What is megalomaniac about the idea of avoiding ultimately useless aerodynamic research? F1 cars need a certain amount of aerodynamic downforce to reach the performance they are supposed to have and to be entertaining.
That does not mean that one always has to destroy the aero configuration as soon as it is optimized and replace it with a completely arbitrary set of new geometrical rules that make no more sense than the configuration before. That is completely artificial and brings no progress at all. It is like wrecking the Golden Gate Bridge every year and rebuilding it in order to stimulate the economy. Nobody would do it.
The money would be much better spend in suspension, engine, material and energy recovery technologies. Those are activity fields that could generate useful solutions to real world problems.
The current focus on optimizing a row of ultimately useless aero configs unfortunately is the darling of all constructors. They do not want the money to go into techologies that they do not dominate. So it looks like we will have to live with the status quo for a long time.
flynfrog
WhiteBlue wrote:
flynfrog wrote:just for sake of actually talking about something technical. Where do you plan to put the DF sensor?
You actually cannot measure downforce alone. You need to measure the balance of all three forces as they occur on the wheels. Hubs or wheel bearings could be a good spot. And then the SECU needs to compute the weight/mass of the car and the inertial forces in order to subtract them from the balance. But as previously shown it would not be a big deal.
thats not exactly trivial
flynfrog
What real world problems do you really think F1 will solve? As I pointed out earlier your rule would do nothing to limit spending on AERO just changes the focus. Last I checked Technology flowed up from F1 not down from it.
Right now the biggest gains to be made it fuel consumption in the real world are areo problems not suspension not engine. But once again F1 will have nothing to do with fixing either of those.
bhall
bhall
244
WhiteBlue wrote:What is megalomaniac about [...]?
The megalomaniacal part is because every time you get the bright idea to save something from itself, you almost always begin your rationale with the words, "I want." I think that's very telling. You also seem to want changes that no one else wants, a fact that never seems to bother you.
WhiteBlue
92
flynfrog wrote:What real world problems do you really think F1 will solve? As I pointed out earlier your rule would do nothing to limit spending on AERO just changes the focus. Last I checked Technology flowed up from F1 not down from it.
This post confirms a misunderstanding of the objective and a wrong concepts about aero in road cars.
The objective of the DF fixing rule proposal is avoiding to spend money in aero research that is wasted on irrelevant configuration changes. The money should go into engineering fields which are relevant to high performance and average vehicles.
The reversed flow of technology is because F1 has the wrong incentives. It would be better to free up the rules in technology fields that attract more automotive companies. We have only two who are really involved beyond sponsoring and they have often enough criticised it.
Aerodynamics is actually a very small activity in the road car industry compared to engine, combustion, ignition, turbo charger, fuel injection, down sizing, electrification of ancillaries, hybridization, battery, electricity storage, light weighting with affordable materials, and other fields of research.
WhiteBlue
92
It is not trivial indeed but compared to other things that have been done in F1 (active suspension, two way telemetry, sophisticated engine mapping for downforce generation) it is a task that can be solved with relative ease. After all aircraft and submarines have done it for fifty years. You once solve the problem you automate the solution and then you can forget that there once was a problem. You just have to do it. And there lies the crux. The constructors have an agenda that does not agree with the motivation. They do not want that technologies common in general automotive fields are promoted in F1 because it would not suit their own competencies.
bhall
bhall
244
WhiteBlue wrote:And there lies the crux. The constructors have an agenda that does not agree with the motivation. They do not want that technologies common in general automotive fields are promoted in F1 because it would not suit their own competencies.
Your point being...?
And how is that any different than going against the collective will of the teams just to suit your agenda?
flynfrog
Your post confirms you lack of a grasp on reality F1 has never been and never will be about research for road going cars. Your solution to freeze DF levels will not begin a shift away from areo as I pointed out earlier.
A streamedlined shape in a production car will make magnitudes more gains in fuel economy than any of those things you posted. People just dont like the way they look.
Simply separation of the vector from areo might sounds easy in your head but how will the FIA make the claim that a spike in down force wasn't caused by a dip in the track? What happens when a sensor fails is a team DQed? measuring aero loads in a steady state is one thing doing it on a race car going around a track is another.
By all means don't let the facts get in the way of your dreams.
bhall
bhall
244
Actually, I take it all back. We shouldn't use petty logic to impede the transference of technology from F1 to the real world.
I'm sure that Dietrich Mateschitz is simply dying to reduce all can-related drag so that his Red Bull energy drink can go from container to stomach as quickly as possible. And I think F1 is obviously just the place to carry out the necessary R&D.
Pingguest
Pingguest
WhiteBlue wrote:I have little doubt that with current electronics and advanced sensors a real time computation of the total downforce is possible.
It should be possible to regulate the available power by adapting the fuel consumption rule in the future. If you also enforce a legal downforce level you can limit aerodynamic activities to drag reduction.
In case the downforce is to be limited explicitly to a comparatively low amount - e.g. 750 kg - any fuel consumption limit becomes unnecessary, as cars would lack the required amount of grip for a constant increase of engine power. Particularly if Formula 1 would adopt all-weather tyres which last the entire race distance as well.
It would allow a massive deregulation in areas such as engines (any design to be allowed), weight, bodywork (ground effects, fans, active aero, active suspension), transmission (four-wheel drive, maybe even CVT) and tyres (no longer standardized). I doubt any regulation stipulating a minimum longevity - e.g. post-qualifying parc fermé, five-race gearboxes and the maximum of eight engines per season - would be necessary either. As creating a winning car will become a matter of creativity, intelligence and human instincts instead of using an increasing amount of resources, costs may well go down.
JohnsonsEvilTwin
Apologies for going off kilter, but can anyone verify roughly how much is lost from the EBD ban?
Naturally I would expect it to very from team to team just a mean figure if possible?
On topic,
Has anyone seen the draft for 2014 aero rules yet? I would imagine there still to be some discussion left in what is due, but I gather the FIA are keen to reduce aero dependance.
Just be good to see and compare the FIA plans to the ideas being put forward here.
More could have been done.
David Purley
bhall
bhall
244
Pingguest wrote:In case the downforce is to be limited explicitly to a comparatively low amount - e.g. 750 kg - any fuel consumption limit becomes unnecessary, as cars would lack the required amount of grip for a constant increase of engine power. Particularly if Formula 1 would adopt all-weather tyres which last the entire race distance as well.
All one has to do is look back at the turbo era to see that low grip did absolutely nothing at all to thwart increases in engine power. Cars during that period featured extremely powerful engines, often well over 1,000 bhp, and aerodynamics that were still in the nascent stages of development. There's no reason to doubt that this would happen again if a downforce cap was introduced in concert with a loosening of other regulations.
If the overall goal is to encourage developments in other areas of the car, a downforce cap is unnecessary. All that's needed to accomplish that goal is for the pertinent regulations to be relaxed. Aero or no aero, I can assure you that engineers would not need to be told where to look for performance gains.
WhiteBlue
92
I'm not going to continue to argue the case further. It appears that the opposition simply hangs on to opinions regardless of the points I make.
One example is the believe that it is impossible to measure inertial forces - or acceleration - precisely in x,y,z-vectors. This opinion is so far from reality that every additional word on the issue is a waste of time and space.
I suggest we agree to disagree on the issue and perhaps continue at a later time if opinions become less entrenched.
