Ferrari SF-26
F1subman25
F1subman25
Re: Ferrari SF-26
So serious question, if the front wing has to be changed during a race, is there a ‘bit’ which needs to be connected to allow the active aero to work? Or will it be as quick a FW change as it was under last regs? Ta
dialtone
dialtone
139
Re: Ferrari SF-26
F1subman25 wrote:So serious question, if the front wing has to be changed during a race, is there a ‘bit’ which needs to be connected to allow the active aero to work? Or will it be as quick a FW change as it was under last regs? Ta
Contacts are embedded in the frame, they engage by fastening mounting bolts. Kind of like when you put back a wireless phone to charge.
matteosc
matteosc
32
Re: Ferrari SF-26
dialtone wrote:
27 Jan 2026, 21:44
That is true if the system is electrically actuated. If there was some pneumatic or hydraulic system, it would be more complicated.
Re: Ferrari SF-26
Front brake duct inlet
#ReleasetheADUO
dialtone
dialtone
139
Re: Ferrari SF-26
matteosc wrote:
dialtone wrote:
27 Jan 2026, 21:44
Even in that case, you put the hydraulic part after the nose and electrically actuate the hydraulic piston.
They already have a standard data connection between nose and chassis, they just reuse that since it’s likely something like CAN bus that they can extend and repurpose for whatever they need.
F1subman25
F1subman25
Re: Ferrari SF-26
dialtone wrote:
27 Jan 2026, 22:14
matteosc wrote:
dialtone wrote:
27 Jan 2026, 21:44
Cheers guys
Peter Ian Staker
Peter Ian Staker
Re: Ferrari SF-26
dialtone wrote:
27 Jan 2026, 22:14
matteosc wrote:
dialtone wrote:
27 Jan 2026, 21:44
Wouldn't you need pressure from the central hydraulic system to actuate the piston? You could use a hydraulic quick detach connector in that case.
Kind of academic though because I suspect most people went for electric motors anyway.
dren
228
Re: Ferrari SF-26
Peter Ian Staker wrote:
27 Jan 2026, 22:39
dialtone wrote:
27 Jan 2026, 22:14
matteosc wrote: That is true if the system is electrically actuated. If there was some pneumatic or hydraulic system, it would be more complicated.
Or a piston that actuates from the chassis and presses into a hole on the nose. Could easily line that up.
Honda!
matteosc
matteosc
32
Re: Ferrari SF-26
dren wrote:
27 Jan 2026, 22:57
27 Jan 2026, 22:39
dialtone wrote:
27 Jan 2026, 22:14
Actually you could have just a small reservoir of oil in the nose and actuate its pump (in the nose) eletrically. In that case the connection would be easy.
dialtone
dialtone
139
Re: Ferrari SF-26
dialtone wrote:
27 Jan 2026, 22:14
You can have a screw and a small motor rotating the screw to generate pressure for example.
venkyhere
43
Re: Ferrari SF-26
dialtone wrote:
27 Jan 2026, 22:14
matteosc wrote:
dialtone wrote:
27 Jan 2026, 21:44
minor addition :
CAN (or any other automotive data protocol) bus is fine to provide enough juice to power a temp sensor or IR sensor etc, but it wont be able to power a servomotor that has to fight against aero-forces to move the flaps up/down. There definitely will be present some kind of 'power lines' as well, alongwith 'data lines' that make a male-female 'connector lock' between the nose stub and the nose when they come together.
Lasssept
122
Re: Ferrari SF-26
sucof
37
Re: Ferrari SF-26
dren wrote:
27 Jan 2026, 22:57
27 Jan 2026, 22:39
dialtone wrote:
27 Jan 2026, 22:14
This is one of the more plausible ones.
I would say, why not a completely mechanical linkage? The hydraulic line ends at the detachment point, in a metal rod, and in the nose there are no hydraulics, only a carbon fibre rod reaching the wing actuator.
One thing to add, is that the wing has to be moved in both direction. So you either add a spring so it jumps back up (or vice versa) or you have to make your mechanical contact to function in both direction. You can not run probably legally with the wing stuck in either position or getting loose.
dialtone
dialtone
139
Re: Ferrari SF-26
sucof wrote:
28 Jan 2026, 00:54
dren wrote:
27 Jan 2026, 22:57
27 Jan 2026, 22:39
There's no other way to do it but a spring, you would need 2 hydraulic circuits, or something very smart, to pull up and down with the same piping. Anyway all of these are likely electromagnetic pistons as it's easiest and most reliable.
Re: Ferrari SF-26
Im looking forward to seeing the non-primordial Ferrari. They usually have lots of interesting tricks
