Possible solutions to improve the 2026 Engine Regulations
WardenOfTheNorth
Re: Possible solutions to improve the 2026 Engine Regulations
De Wet wrote:
28 Apr 2026, 11:52
WardenOfTheNorth wrote:
27 Apr 2026, 17:23
De Wet wrote:
26 Apr 2026, 14:57
Boycott...
Why? The racing is good and I don't really notice the superclipping that much.
Can it be called racing if 80% is controlled by computers ?
Is it 80%? Where do you get that figure from?
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
De Wet
29 Apr 2026, 11:19
De Wet wrote:
28 Apr 2026, 11:52
27 Apr 2026, 17:23
Educated guess. It's most probably more than 80%.
hollus
120% for sure, this is F1 after all. Back on topic, please.
¡Puxa Sporting!
Badger
Badger
46
Sad but predictable. F1 should have never given over the reign to the teams to make these calls.
Jambier
Badger wrote:
30 Apr 2026, 07:57
- Mercedes want to dominate several year, so doesn't want to make changes. That is logic
- Honda needs 16 months to do something so they don't want either a change #-o
Luscion
Luscion
136
Changes for 2027
F1 is back on the menu?
So ICE is roughly 600kw and MGU is 300KW? Roughly 67:33 power split?
Beware of T-Rex
08 May 2026, 16:21
No, according to Thomas Maher: .... now a 50/50 split (closer to 55/45 really) ---> 60/40.
So from 55/45 ---> 60/40. Wow! Just a small change.
FW17
184
The rules do not address the main problem for drivers and fans - regeneration from other than braking
08 May 2026, 16:37
08 May 2026, 16:21
Okay I see. I got confused with the hp to kw conversion. This is a good change.
Beware of T-Rex
FW17
184
This is what happens when the worst Ferrari TP runs F1
WardenOfTheNorth
FW17 wrote:
08 May 2026, 18:30
Really?? This isn't Planet F1 you know.
WardenOfTheNorth
Some talk on The Race about issues around fuel tank capacity and teams wanting to carry over their chassis from 2026...
My question is, could a team modify an existing chassis to accommodate a larger fuel tank?
langedweil
09 May 2026, 13:37
They could, but 10% larger (and thus heavier when full) is quite substantial and would undoubtedly interfere with the chassis structure, aero and possibly even suspension platform as a whole.
Aside from the options mentioned, there is a third one: accept refuelling 😎
HuggaWugga !
De Wet
Why not allow teams to "freeze" the fuel again. Not sure if desired capacity can be reached this way.
